San Marco saddle?
I have been looking at the San Marco saddles, the Mantra Carbon FX and Aspide Carbon FX
I currently have a Fizik Antares R3, but I found its not for me, digs into my sit bones after 25-35+ miles
I sit in the middle/front of the saddle. But when the pain gets to much, i shuffle backwards and find the rear of the saddle push's into the sit bone/ bottom bones/
I was told I needed a more rounder shape saddle?
Any advice?
Any advice?
Fiery wrote:The new Mantra will not be that different from the Antares, except for the cutout. The Aspide is narrower and hammock shaped front to back, but is still quite flat side to side. The only truly rounded saddle in the current lineup is the Concor.
Thank you.
I am not sure on the advice I was given regarding a rounder shape saddle.
I am looking for advice?
If you're finding the saddle is digging into you sit bones then a more rounded shape will let your perineum take more of the load to even things out.
My 2 cents, go to your lbs and see what they recommend. Most shops will let you try saddles for a couple of weeks and if it still doesn't work, go back and try again.
I swap happily between a San Marco Concor on my 'mid bike' and an Aspide Carbon FX on my best bike. The Concor has rather more curved left-to-right contour at the back end, but the Aspide (narrow version) also works for my narrow sit bones and has a waved front to back contour. The Aspide takes a little more settling in/getting used to, and feels more minimal, but i've done very long rides (130 miles) without any problems. I find both a lot more comfortable than pancake-flat saddles, and they look lovely too!
Having had similar problems to you, and having tried a multitude of saddles, the best one I've found is an SMP Dynamic. It has a noticeably curved profile which provides more even support for the pelvis and eliminates the hot spots that flatter saddles caused.
