Cannondale CAAD12 105 complete strip with RAW weights
- prendrefeu
- Contact:
FSA = boat anchor
Great thread. I bought a Hylix Seatpost for my Synapse 131g claimed weight. Not much that is lighter than that
http://www.ebay.co.uk/itm/Hylix-Carbon-Seatpost-25-4-400MM-131g-for-Cannondale-Synapse-Fit-7-9-Rails-/291702903767
Ordered yesterday - now the long wait for the caad12 frameset and the potentially longer wait for the seatpost - hopefully they arrive about the same time. Must admit, find it quite odd UK distributor doesn't supply with a seatpost given the marketing about 'system weights'.
Why not run a thomson seatpost only 180 grams and look great imo
- prendrefeu
- Contact:
The Cannondale cranks (SiSL and SiSL2) are anodized black. This can be removed with oven cleaner or simply polished off (although oven cleaner then polish would be a better method). If you want to re-anodize them some Ano service companies may reject it because two haves of the crank are essentially 'glued' together, others will take it anyway. It's mostly out of fear that the acids in the process will destroy the bond... Perhaps in some cases or some methods this may happen, but in common anodizing the acid used will not harm the bond.
- prendrefeu
- Contact:
tmr5555 wrote:A chrome Coloured fork to match?
No... although I thought about it. The fork, after 3 months of waiting ( ) finally arrives today. The frame at this moment looks different from what is pictured in this thread, although I did take pictures of it after polish and before "phase 1" of the design. Now that the fork will arrive I can finally start the build thread for this, although it will be a slow build... some parts are still on order/waiting for delivery, some parts will need to be custom ordered post-fitting, and I have some more tuning to do on components.
Cannot wait to see a build thread on this!! Looking forward to seeing your component choices
- btompkins0112
Damn, P-dawg.....that is FINE
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
Keep the updates coming!
You have more patience than I do ..... I started a new CAAD build myself and just picked up the frame from the painter only to find that they had messed it up. However, I have just decided to build it & ride it this year and use someone else for paint next winter. Who knows, I might even anodize it after I see yours completed.
Two wheelers rock!
Does anyone know why the release of the CAAD12 frames in the UK have been delayed so many times now? I was first told February then the middle of February then a week later then I was told April 8th, then I phone in to be told they will be in may 5th, I lost confidence in them ever coming and cancelled my order and bought a full build which is such a waste as I will be stripping it down to fit SRAM Force groupset.
I'm just confused did the slow boat sink or get hijacked? is my pre-ordered frame now a hostage in Somalia?
