Rotor Q-ring question
Tinea Pedis
by Tinea Pedis
addictR1 wrote:
grouk wrote:QXL 52/36 and zero shifting problems you only need good adjustment and chain catcher, and i didnt use the spacer that rotor recommend
Are you using a RED 110BCD crank?
He would have to be. If you look at the BCD for that ring size you'll see it's 110. So long as you get the BCD correct GXP or BB30 axle does not matter.
I have just gone back to round rings on my road bike - but keeping QXL on my TT rig. Run P2M on all my bikes. Have found a slight power difference between the Q-Rings and round (same as found in the Twitter link). I liked the q-rings, just gone to round rings to see if I can feel a difference. So far...not. But would not be without them on the TT bike.
addictR1
by addictR1
Sweet.. Thx
Grill
by Grill
Tinea Pedis wrote:I liked the q-rings, just gone to round rings to see if I can feel a difference. So far...not. But would not be without them on the TT bike.
It's beneficial to train on round and race on oval/O'sys. Reckon you might recover a bit quicker as a result. ;)
TomColnago
by TomColnago
I raced and trained on Q rings for nearly a year and have found a big advantage with them with me is that I spin a higher cadence. I used to be a churner but when I made the switch to the Q rings I was spinning more in all my gears and found that it took a lot longer for fatigue in my legs to set in. hope this helps :D
grouk
by grouk
that is my setup
as i said never had shifting problems but chain catcher is a must
Grill
by Grill
Even with no ramps, my Fibre-Lyte O'sys style rings shift better than my Q-Rings ever did.
addictR1
by addictR1
How are the Qring vs Osys differ? The Osys chai rings seems to cost a bit more?
nefariousintent
by nefariousintent
So osymetric = more foot speed... Haha
Using Tapatalk
jorisee01
by jorisee01
Grill wrote:Even with no ramps, my Fibre-Lyte O'sys style rings shift better than my Q-Rings ever did.
Where did you buy these rings?
Grill
by Grill
addictR1
by addictR1
How much did that cost?
superdx
by superdx
Oh man, this thread is sending me to the bike shop this afternoon for q-rings
tinozee
by tinozee
Regarding power meters, slope and inaccurate readings - if you use a quarq they have a calibration table that you can follow to setup your rings. Normal and qxl are in there. once you adjust the slope the readings are the same as you'd get on round, and it's not a huge diff in slope from stock at all anyway.
Grill
by Grill
I don't remember offhand but they were less than O'sys rings.
