Do 10 speed di2 levers work with 11 speed derailleurs?
520 Dan
by 520 Dan
As above, do 10 speed shift levers work with 11 speed components as long as everything is E-tubes? Seems like it would but I don't know anyone who has tried it and I don't have 11 speed stuff kicking around. Thanks
Birdman
by Birdman
If is e-tube then it will work. For sure it will.
Cervelo R3 MUD ~ viewtopic.php?f=10&t=136544
Specialized Allez Gold ~ viewtopic.php?f=10&t=134419
2old4this
by 2old4this
Here is an excellent article on di2 component compatibility...
http://carltonbale.com/shimano-di2-ever ... d-to-know/
Ritxis
by Ritxis
520 Dan wrote:As above, do 10 speed shift levers work with 11 speed components as long as everything is E-tubes? Seems like it would but I don't know anyone who has tried it and I don't have 11 speed stuff kicking around. Thanks
No problem, I have used Ultegra 6770 10 speed shift levers with Ultegra 6870 11 front derailleur and Dura-ace 9070 11 rear derailleur
Multebear
by Multebear
I did the opposite, which worked fine. I have 11-speed 9070 shiftlevers, and they work fine with 10-speed 6770 front- and rearderaileur. It works as a 10-speed gruppo though.
Ritxis
by Ritxis
Multebear wrote:I did the opposite, which worked fine. I have 11-speed 9070 shiftlevers, and they work fine with 10-speed 6770 front- and rearderaileur. It works as a 10-speed gruppo though.
rear derailleur is who ordains
Birdman
by Birdman
2old4this wrote:Here is an excellent article on di2 component compatibility...
Very nice article, just in time for my new Di2 group :)
ophiravina
by ophiravina
does the 10 speed front derailleur also work? can I use a 10 speed front deraileur and shifters with 11 speed rear der and cassette?
eliflap-scalpel
by eliflap-scalpel
ophiravina wrote:does the 10 speed front derailleur also work? can I use a 10 speed front deraileur and shifters with 11 speed rear der and cassette?
normally not.
but it depends on each firmware installed in every part.
http://eliflap.it/
Ritxis
by Ritxis
If the battery internal or external mount firmware is 3.0.5 or top, front derailleur 10 speed (Ultegra 6770) does not work with rear derailleur 11 speed
