Specialized S-Works crankset, Praxis rings
Birdman
by Birdman
170 crank arm length
Compact alloy spider from another fellow WeightWeenie.
Praxis 48/36 rings
Total weight should be
= 236 + 149 + 4 + 104 + 35 + 24
= 552g
Drive side arm + alloy 110 spider + drive side BB30 spacer
None drive side arm, no spacer
Alloy 110 spider
Carbon 130 spider
Cervelo R3 MUD ~ viewtopic.php?f=10&t=136544
Specialized Allez Gold ~ viewtopic.php?f=10&t=134419
Alpine318is
by Alpine318is
48/36? What kind of bike is this going on?
2018 Specialized S-Works Tarmac
SRAM Etap
ENVE 4.5
2018 Bianchi Infinito CV
SRAM Etap
ENVE Classics 45
2016 Cervelo P2
Ultegra 6800 Di2
ENVE 6.7
MichaelB
by MichaelB
Very similar to my setup !!
I've got 172.5 arms (stripped) with 50/34 Praxis rings, the Qman alloy spider but have steel chainring bolts atm, as that's all I could get locally in stock :evil: . The alloy ones I had were too short, but will be sorted.
Will weigh all my bits to compare !!
Birdman
by Birdman
Alpine318is wrote:48/36? What kind of bike is this going on?
Specialized Allez in gold :)
I am not that strong of a rider. I don't use my 50/11 combo often so I thought I give this a try. Is only a 4% difference anyways.
Birdman
by Birdman
I got steel chairing bolts too. I rather gain a few grams on the bolts for better durability.
Birdman
by Birdman
MichaelB wrote: ... Qman alloy spider ...
Jealous...
Ozrider
by Ozrider
Alloy chainring bolts are durable and will save quite a few grams
Parlee Z5, Trek Madone, Jonesman Custom
Ozrider - Western Australia
2old4this
by 2old4this
I use a 48/34 CarbonTi on the hills. Not the best shifting experience but works when the total ascend is 4-5k ft...
Birdman
by Birdman
The catch pin on the big Praxis ring is too long. It interfer with the crank arm.
I filed it down and it now clears.
wingguy
by wingguy
Birdman wrote:Specialized Allez in gold :)
No hills where you live? Seems odd to me to ditch the 50 but keep the 36 :noidea:
Birdman
by Birdman
Assembled = 554g
Alpine318is
by Alpine318is
Oh I'm totally with you. I ride 50/34 with an 11-23 cassette. I ride most flat ground and I like the tight spacing. Completed crankset looks great!
SRAM Etap
ENVE 4.5
SRAM Etap
ENVE Classics 45
2016 Cervelo P2
Ultegra 6800 Di2
ENVE 6.7
Birdman
by Birdman
Need a S-Works Torx T45 tool... Does anyone know if:
1. Where can I buy the tool that ships to USA.
2. Any CONFIRMED compatible none Specialized tool? Craftsman?
The one that I have is too thick except for the tip... WTF Specialized!!!
I rather have the tool to keep than going to my LBS every time I need to get my crank on and off.
MichaelB
by MichaelB
Birdman wrote:Need a S-Works Torx T45 tool... Does anyone know if:
I may have a spare one that I could part with. I'm in Oz, so there would be some shipping.
Mind you, I've seen them on ebay too for about USD$16 + shipping
cerro
by cerro
Carbon spider 110mm is 45g :) I got a pair for my bikes
