What's that frikin' noise?!
I recently put together a bike, carbon frame and ultegra 6800 group, and all's well now except for an annoying noise come from the crank area.
It sounds like the chain is rubbing on the front mech, but it clearly isnt. It only happens in 1st, 2nd and 3rd gear and is at its worst in 1st.
The rear hanger was a bit out so I had the LBS sort that. There is no noise when running without a chain. The alignment seems fine so what could it be?
Any ideas?
Any ideas?
you check the FD cage to see how its aligned with the chainrings? there's also a screw that secures and firms up the FD when shifting...requires gluing a little metal plate on the frame.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
- Stolichnaya
By first gear, do you mean the smallest cog on the cassette?
Amd if yes, does this sound only occur when the chain is on the small chainring or on both?
If it only occurs when the chain is on the inner chainring, then check your chainline because the chain my be rubbing on the inside of the large / outter chainring.
had the same with my 6800 group! The chain wasn't mounted correctly.
After mounting it like it should, the sound was gone.
my chain was an Ultegra chain, wich has a mounting direction.
I mounted it reversed...
I am experiencing a similar thing. Will likely take it to my LBS for a check-up. I'm running Ultegra di2.
simacu wrote:I recently put together a bike, carbon frame and ultegra 6800 group, and all's well now except for an annoying noise come from the crank area.
Any ideas?
