flafonta
by flafonta on Tue Jan 12, 2016 9:28 pm
Raineman wrote:wingguy wrote:
I wonder if they've made other changes to the frame, notice the "hop" around the back of the brakes on Sagan's newer bike vs Cav's TdF one. Tire clearance on the frame appears tighter too.
The notch for the back of the brake is visible on the current VIAS pictures on the Specialized website.
oreoboreo
by oreoboreo on Thu Apr 07, 2016 2:25 pm
On many cars there are vents to help cool the brakes. I like to think that that bike is so fast and the brakes do not get direct airflow so they had to run vents. I still like the pitot tube comment as well.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
bas
by bas on Mon Jul 04, 2016 3:39 am
Bikeradar coverage of his bike indicates they are fitting new brakes to all the Venge bikes, anyone with info on this?
I've just ordered one but will make sure it comes with new brakes if its the case.
MRM
by MRM on Wed Jul 19, 2017 11:52 pm
I think it is standard on the 2017 model. Mine (disc version has it). So, you should be able to purchase it via your Specialized dealer. After checking the website, might only be the case for the disc models. You will probably have to talk to the Specialized dealer.
53x12
by 53x12 on Thu Jul 20, 2017 12:32 am
Ludo wrote:does someone know if there is a chance to buy a fork with external cable-routing ?
Unfortunate that Specialized had to go this route to deal with the poor braking performance. Looks like a Giant Propel with the poor cable routing now blowing in the wind.
topflightpro
by topflightpro on Thu Jul 20, 2017 1:44 pm
53x12 wrote:Unfortunate that Specialized had to go this route to deal with the poor braking performance. Looks like a Giant Propel with the poor cable routing now blowing in the wind.
As someone else noted, I'm pretty sure Specialized only did this to accommodate the non-specialized cockpit, as well as make it easier to swap cables/housing if needed during the tour.
