Need advice on wife's dream build
modman
by modman
Well, it's all ordered. Thanks again for everyone's help. Here's the list of what she finally settled on:
  • 44cm Cannondale SuperSix EVO Black Inc.
  • SRAM Red 22 Brifters/Derailleurs/Brakes
  • DuraAce C24 Clincers
  • Power2Max Rotor 3D+, 160mm compact crankset with Praxis rings
  • Zipp SL-70 36cm bars
  • Essor Flight-Weight Seatpost
  • Uno Stem
  • Ultegra Cassette
  • KMC X11SL Chain
  • Pedals/cages/saddle will be brought over from current setup.
The frameset arrived and was unboxed this weekend. I'll post photos/weights as soon as I can and follow with the other components as they arrive and are installed. Should be a fun build on my end; she's excited to ride it.
oreoboreo
by oreoboreo
and today is short girl appreciation day. I have one (5') also and appreciate her, I went the ruby/ ultegra route, since she only does weekend
rides. Great build list!
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
modman
by modman
Parts have been coming in and should start the build sometime this weekend. Here are some teaser shots. Weights are with all bolts attached, and frame still has hanger installed and cable liner in place. Fork is obviously uncut. Not bad!
PSM
by PSM
I think I just fell in love with your wife. 8)
modman
by modman
A few more... She decided on a Chris King BB.
srshaw
by srshaw
I didn't think Chris King made anything for modern bottom brackets. That looks great.
modman
by modman
srshaw wrote:I didn't think Chris King made anything for modern bottom brackets. That looks great.
I think their PF30 has been out for a year or so. Never had one of their bottom brackets, but heard good things. Looking forward to installing it and seeing how it holds up in the weather.
Delorre
by Delorre
maxxevv wrote:
cyclenutnz wrote:3T don't make any really short reach bars. Better to look at Zipp SL70 or Profile DRiVe 105.
Arundel sideloader cages in Matte Black...
The shortest 3T ones seem to have a 80mm and 85mm reach.
The shortest I've come across was a Profile design one that has a 70mm reach, the Canta SS.
Deda has a Superzero in 75mm reach too.
That being said, different manufacturers have different ways of measuring reach, so the measurements cannot be taken as being directly interchangeable between different makes.
The Canta ss has a similar reach as the easton ec90slx, at least in real terms. Check my both rides ;-) Canyon fitted with Easton, the Scott with Profile Canta SS, both are the same, at least with Campa vs Shimano leavers. Don't know about Sram, sorry!
Delorre
by Delorre
[quote="modmanImage
Image[/quote]
Is that with or without rim tape?
modman
by modman
Delorre wrote:Is that with or without rim tape?
With rim tape installed.
Delorre
by Delorre
modman wrote:Image
I expected the weight to be lower, being a black inc and the smalest size. Bith uber mjammy frame alltogether!
CamW
by CamW
My meticulous mechanic friend doesn't rate the Chris King BB's as a whole although the bearings are good. He swears by the plastic cupped pressfit BBs as they are more tolerant of less than perfect frame tolerances.
modman
by modman
Well it's finally built and she's out for her inaugural ride now. Final build photo before fitting is attached. Will post some more including final weight after everything's dialed in and the steerer is fully cut. Thanks again for all your input.
