How can i reduce the weight?
arijelkins
by arijelkins
Hey Guys,
I just got a new Cannondale Caad12 Ultegra and it weighed in at 17lbs with my cheap performance bike pedals. I was wondering what are some cheap changes that i can make to bring the weight down.
Frame:
CAAD12, SmartFormed 6069 Alloy, SPEED SAVE, BB30a, Di2 Ready
Fork:
CAAD12, SPEED SAVE, BallisTec full carbon, 1-1/8" to 1-1/4" steerer, integrated crown race.
Derailleurs:
Shimano Ultegra 6800
Number of Gears:
22
Shifters:
Chainset:
Cannondale HollowGram Si, hollow forged, w/ OPI SpideRing, BB30a, 52/36
Bottom Bracket:
FSA BB30 Bearings
Cassette:
Shimano Ultegra 6800, 11-28, 11-speed
Chain:
Shimano HG700-11, 11-speed
Brakeset:
Handlebars:
Cannondale C2, butted 6061 Alloy, Compact
Stem:
Cannondale C2, 7050 Alloy, 31.8, 6 deg.
Headset:
CAAD12, 1-1/4" lower bearing, 25mm top cap
Grips:
Cannondale Bar Tape w/Gel, 2.5mm
Wheelset:
Mavic Aksium Elite WTS
Front Tyre:
Mavic Yksion Elite Guard, folding, WTS, 700×25c
Rear Tyre:
Saddle:
Fizik Arione R7 MG Rails
Seatpost:
Cannondale C2, UD Carbon, 25.4×300mm
kkibbler
by kkibbler
I'd start with wheels, tires, handlebars.
Tooslow
by Tooslow
Carbon frame.
Sorry, had to say it. LOL!
btompkins0112
by btompkins0112
kkibbler wrote:I'd start with wheels, tires, handlebars.
This is the best advice
CEVelo
by CEVelo
After wheels, tires and handlebar, I'd replace the cassette & saddle for some more gains.
Then the groupset if you really want to get after it.
stormur
by stormur
Eat less , ride more :)
I never felt any measurable difference ( I know it is, just didn't felt it ) reducing weight of the bike. In 2014 I weight 8kg less than 2013 - THAT WAS DIFFERENCE.
But if it must be bike weight reduction ... 6800 is 300g heavier than Force22/Chorus. Stem is very OK, handlebar : u can save 40g ( aboutish ) going to CF ( C2 is light alu ) . Wheels / tires : here 400g is easy to get at "below 1€/1g" - 1500g wheels + latex tubes + open tubular tires. Saddle : 100g down going to Selle Italia ( chepaer than Fizik for given weight , much cheaper ) .
So all of "improvements" are financially placing you at level of new ,stock Cannondale Supersix Sram Red ( price , Ssix will be still lighter ) ... was it worth it - decide yourself ;)
Mark Twain
Devon
by Devon
Always wheels first. But you should use heavier wheels for training.
Marin
by Marin
Make a list with all weights 1st and list lighter alternatives you can afford.
Basically, saving weight off a complete build is a waste of money and won't get you far.
Only change parts where you have other benefits than weigh savings, i.e. better looks or function.
eric01
by eric01
Wheels. Always wheels first. A mid-level frame with mid-level components will feel faster with lightweight/aero wheels than a high end frame with crappy wheels.
crankinstein
by crankinstein
If you're about to dump a pile of money to lighten a new bike, you should have just bought the light bike.
Sent from my SM-N910W8 using Tapatalk
CPongpanich
by CPongpanich
The wheels I would say. Not reducing weight but improve the ride quality considerably.
RimClencher
by RimClencher
Check the weight of the expander plug and see if you can save weight with this (weighs 16 g):
http://www.cannondaleexperts.com/Cannon ... p_106.html
junchen
by junchen
RimClencher wrote:Check the weight of the expander plug and see if you can save weight with this (weighs 16 g):
Can this be used for other frames with the r5?
Sent from my SM-G920I using Tapatalk
victorduraace
by victorduraace
Wheeels bars saddle and premium tires like Veloflex
New frame or groupset will cost a lot more
CAAD997
by CAAD997
As many have already stated ........ wheels and tires to start.
Something else you might try is to create a spreadsheet with the following columns:
part name
OEM part weight (g)
New part weight (g)
Weight savings (g)
Cost of new part ($)
Anticipated sale price of OEM part ($)
Net cost of new part ($)
Net cost: [net new cost]/[weight savings] ($/g)
The various columns can shed new light on how you look at reducing weight or where you spend your money. A new $500 part that saves 10g is going to look a lot more expensive than some other options. Have fun with it!
Two wheelers rock!
