Stripping Campagnolo carbon crank
stormur
by stormur
Did anyone done that ?
I mean removing all logos from the UT carbon crank (2011-2014).
Thanks in advance , but for EXPERIENCE only ;)
Mark Twain
Delorre
by Delorre
Been there, done that, but never ended the 'project'. I had a hard time stripping all the clear + lettering with a razor blade was. I don't have pictures of the drive side, but the look of it was dull, boring, ... As it never been clear coated after that, I can't comment on the final look, but a layer of (at least satin gloss) clear is really needed to obtain the classy campy look again.
stormur
by stormur
I've read somewhere that amount of clear coat in Campagnolo carbon cranks is enormous...
If I decide to strip logos, naturally I'll paint it back for glossy with automotive clear coat ( with some additives like for bumpers, to keep it elastic- but I'm not a pro at this area, so forgive my ignorance... )
Mark Twain
petepeterson
by petepeterson
I have not done this with campy cranks but I have experience with sanding and re clear coating lots of other stuff. You should only have to wet sand the clear in the area of the logo and then re-spray that clear.
