Ruds
by Ruds on Wed Dec 02, 2015 4:42 am
Hi everyone,
I have a friend who is using a Record tubular for a race and would like to remove the name from them. Does anyone have any ideas?
The name seems to be printed on, I'm worried about solvent though incase it damages the rubber. Any ideas would be welcome.
Thank you
Ruds
by Ruds on Wed Dec 02, 2015 6:34 am
I'd thought about that, seems the most logical doesn't it? Might try it on some other markers for the solvent and go from there, thank you
jwfinesse
by jwfinesse on Wed Dec 02, 2015 7:02 am
Acetone will take care of it right away, and it evaporates fast enough to cause no damage to the rubber. I dip qtips in acetone and use it when white veloflex logos get dirty enough.
Ruds
by Ruds on Thu Dec 03, 2015 3:46 am
jwfinesse wrote:Acetone will take care of it right away, and it evaporates fast enough to cause no damage to the rubber. I dip qtips in acetone and use it when white veloflex logos get dirty enough.
Thank you!!!!
Ruds
by Ruds on Wed Dec 09, 2015 4:38 am
Just to close this out, Acetone worked perfectly
The rubber wasn't damaged and the logo wiped off leaving nearly nothing behind it. Not noticeable from a meter away. Thank you.
