SRAM Red RD with 28t cassette
NiFTY
by NiFTY
I have just switched to a 28 tooth cassette with my SRAM Red RD (original series) and am having trouble dialling it in. The 25 shifted perfectly. Chain is the same and there was enough length that I can just run big big. After adjusting the B adjustment screw so the derailleur clears the 28 the derailleur will have trouble dropping into the 11. If the cable tension is reduced to drop into the 11 quickly the shifting and running in the top three sprockets is awful.
Hanger is straight. Cables and housing are smooth, limits are correct.
I notice that on the newer SRAM Red (Yaw) series the derailleur description says improved clearance for 28 tooth cassettes. Is this a know problem. Anyone have this problem and have a fix?
aaric
by aaric
You can stick a washer under the mounting bolt for the rear derailleur to move the whole derailleur assembly over a bit, which gives it a bit more clearance.
You could also check if your frame has different rear derailleur hangars for larger tooth counts - Specialized has a longer hangar for instance - my SL3 tarmacs had the exact issue you describe with the shorter hangar.
Marin
by Marin
I have a new and an old one, both on 11s drivetrains, and the new one is perfect even on an 11-32 cassette, while the old one is hard to dial in on 11-28.
I'll probably try the washer trick too.
UpFromOne
by UpFromOne
IIRC, the old version of that derailleur was only rated to 27t, but maybe that wouldn't factor into the travel?
NiFTY
by NiFTY
aaric, thanks, it is a SL3. I will check which hanger it has (long or short) i hadn't even thought of that. The washer behind the derailleur bolt has been tried and didn't help. Thanks to all responders.
diopena1
by diopena1
NiFTY wrote:I have just switched to a 28 tooth cassette with my SRAM Red RD (original series) and am having trouble dialling it in. The 25 shifted perfectly. Chain is the same and there was enough length that I can just run big big. After adjusting the B adjustment screw so the derailleur clears the 28 the derailleur will have trouble dropping into the 11. If the cable tension is reduced to drop into the 11 quickly the shifting and running in the top three sprockets is awful.
I chased this unicorn, and managed to get it to work. My setup is a 10 speed Yaw, and its on a Cannondale Supersix. Now, Originally I was running a Dura Ace cassette (11-27) without issues on my 11 spd compatible freehub. I did some scrounging about, and found out that there was a difference in the cassette spacing for Sram, after changing out the Dura Ace for a new xg1090 11-28. Now, I also have the short rear derailleur, which has been rated to handle a 28t cog max... My fix however took me down the "rabbit hole", I ended up getting a thicker spacer (1.8 instead of 1.7mm), B screw was adjusted a bit, and it's working, just not as smooth as my 11-26. Spacer cost me all of $6. In your case, I'd suggest getting the longer hanger, as it will move the derailleur down a bit, thus, allowing easier mobility into a bigger cog. This is the same theory behind running a Medium derailleur cage. Extending the derailleur arms reach, allows you to run the larger cogs easier.
rpenmanparker
by rpenmanparker
aaric wrote:You can stick a washer under the mounting bolt for the rear derailleur to move the whole derailleur assembly over a bit, which gives it a bit more clearance.
I only use 26-tooth largest cog Red cassettes, but I also had a similar problem of not being able to drop the chain onto the smallest cog with a new, replacement cassette even with the high limit screw all the way out. Manufacturing defect in the width of the cassette? I don't know what it was, but I found the spacer trick mentioned above to work great. I put a 2 mm washer between the RD and the hanger and voila, shifting to the smallest cog was fixed. Still plenty of derailleur travel to also get up on the largest cog at the other end after resetting the low limit screw. Works great.
Robert
Marin
by Marin
Hmm I think I'll try a smaller top pulley, have one sitting around.
Rascal
by Rascal
I've just finished setting up my 2004 TCR running Red with a DA 11-28. I used a 1mm washer behind the rear D, also using Wheel's Manufacturing hanger and a KMC 11spd chain. No problems with bike in stand; need to get out and test it on the road.
-Giant TCR
-CAAD5
-Klein Rascal
NiFTY
by NiFTY
Yep, spacers behind the RD works.
addictR1
by addictR1
Marin wrote:I have a new and an old one, both on 11s drivetrains, and the new one is perfect even on an 11-32 cassette, while the old one is hard to dial in on 11-28.
how did you get the old RED RD to run 11/32? when i tried.. the jockey would be so close to each other that it's mushing the chain in between.
NiFTY
by NiFTY
I think the problem is also the geometry of the RD body rather than just cage length and upper pulley clearance. I have a wifli cage to run an 11-30 ( think the long cage seems to make it shift more reliably than my old sram red black as there is so much chain take-up capacity.
Marin
by Marin
I didn't?
addictR1
by addictR1
marin, guess i misread.. thought you had tried the washer trick to get the 11/32 to run on the red RD.
I was able to get the Ultegra 6700 - 12/30 to run with Red RD (10sp)
