Carbon Speed 2016 road disc thru axle frame CS-092 SL
Carbon Speed 2016 road disc thru axle frameset CS-092 SL.
Shimano newest flat mount, 100x12 thru axle fork, 142x12 thru axle frame, 966g only for size 58cm
BB option: BB86
700C*28 max tire size
What do you think ?
BB option: BB86
What do you think ?
Here is the link: http://www.xmcarbonspeed.com/Productinfo.asp?f=1420
Hi guys,
I recently completed a build using this frame the CS-092. All carbon parts were obtained from Peter at Xmcarbonspeed. I was hoping to attach some photos. I've been extremely happy with the build thus far.
CS-092 size 54cm---955 grams with paint
b6 400mm handlebar
st2 110 mm stem
38mm front and 50mm rear clincher wheelset built on dt-swiss 240s from Peter
Drivetrain is all Ultegra Di2 with the exception of the Dura-ace crankset and pedals.
Final weight is 7.88 kg
I've taken it for a couple spins and have been very pleased. Probably take it out for a couple more easy spins to build some confidence then I'll start putting it through the paces.
b6 400mm handlebar
st2 110 mm stem
Here is mine
Size 58 from Peter at xmcarbonspeed.com
Mostly Ultegra (cable), bars (b6) and rims (38mm) also from Peter, Hope hubs, Sapim spokes (32 CXRay).
Still playing with the fit. I am a bit odd as I am 6'3" with a short inseam and long torso.
Currently a -6degree stem, but I am going to try a -10 and -17 as the -6 puts the bars a little too high.
For what it is worth, mine was the frame pictured and weighed at 966 grams in the original post. On my scale it was 971 with the guide tubing in place so I would say the 966 was pretty accurate. I got 383 for the fork, and 213 for the proprietary D shaped seatpost. I am very happy with the quality, fit and finish of the frame, fork and post.
I will update my opinions when I have some real miles on it.
