Enve 3.4 or 4.5 Tubulars ???
Dude, you live in Florida. There are no scenarios where weight matter. 6.7 or 8.9. Save the 3.4 for windy days.
^ depends on his weight really and ride preference. 6.7s and 8.9 will be fast but feel more sluggish than the 3.4 or 4.5.....and its windy a lot in coastal areas.
Reality is he's going to spend 2500 on NEW ENVEs and ride them 10 times a year(since they are race day only). That's why I told him to consider the used market for the 3.4s. He's not going to listen becasue he has a hole in his wallet. Been there done that and have 5 wheel sets in house now to show for it including some low mileage race day C24 tubs getting low low use due to glass where I ride.
OP do the math. Do you want to spend $2500 for new tubs for 10 rides a year? OR get clinchers that are not going to be slower and actual get to ride them a lot?
Now if you said you really want tubulars for the ride characteristics, or safety etc., then tubulars are the right decision.
Your money good luck.
mimason wrote:^ depends on his weight really and ride preference. 6.7s and 8.9 will be fast but feel more sluggish than the 3.4 or 4.5.....and its windy a lot in coastal areas.
If he's racing, the fastest wheel he can handle with the wind is the best. Again, key variable being wind. Moment of inertia differences are moot at best and I've known really light guys to ride really deep wheels (Contador has ridden 808s on tons of stages even, some cat 1 friends that are 125-125 race on 60mm wheels fine).
If cost is a concern, I'd shop for something middle of the range or a 4.5 and sell the others.
This is all good discussion and correct. Not a big difference in spin up but the handling, feedback, steering and interaction with wind is considerable.
OP, consider renting some tubulars for a race or local riding before you decide or see if the local shops will demo them for you.
Bmwx5gcc wrote:Thank you for all your feedback and advice much appreciated.
I have decided to go with Enve 4.5 Tubulars.
Thanks again !!
Good decision! You might want to check with Enve before you buy, though, as I have heard that the 4.5 will be updated with the improved brake track they first introduced on the 2.2 rims.
So I decided to go with the Enve 4.5 Tubulars for all the above mentioned reasons. I currently have the 4.5 Clinchers.
Clincher set has Continental GP4000s II 25mm
Tubular set has Continental Competition 25mm w/ tufo tape
I weighed all the complete wheels and the results are
Tubular FRONT is 130 grams lighter than the Clincher
Tubular REAR is 77 grams lighter than the Clincher
Total Tubular set is 207 grams lighter than the clincher set.
Doesn't seem to be enough of a difference to justify having both sets.
In WW-land 207g is quite a bit though!
cf a frame that weighs 893g vs a frame that weighs 1100g
One is modern WW carbon weight, and the other is 12 year old alu weight!
Now you've got them ... I'd keep them both
Bmwx5gcc wrote:So I decided to go with the Enve 4.5 Tubulars for all the above mentioned reasons. I currently have the 4.5 Clinchers.
Weight would have been easy to determine before you purchased them. You got them so ride and enjoy as they are worth 50-60% of MSRP now and selling may not be a good idea.
