Woot! Extralite Stem
OP's stem doesn't look like that with the sharp edges rounded off, must be old stock
OP why is your stem so short ? do you realise the steering will be extremely quick, it's would be better to get a 100mm stem, if you can fit that.
Is your frame too big for you ?
WannabeWeenie: haha.. i have to agree with you on the wrapping thumb pat. i'm not a big 1911 fan.. so the 1911 i picked up is the SA1911 target model with a nice dovetail in the back to prevent slide bite.
wow.. thanks for sharing that cuz i guess the one i got was old stock like the one other ppl had with bite marks in the stem.
i did just that and rounded off the edges.
lannes: yes i'm aware the shorter stem = quick turns.. which i like. before i was running a 90mm Uno stem and that was good too, but on my CX I'm using a 80mm and felt pretty good. overall looks like the -12 degree might just work out.. looks parallel to the ground and slammed.. just hope my back can handle it.. old man here...
PSM wrote:From Extralite today:
- wheelsONfire
How come Sergio and the boys shared this drawing with you?
Bikes:
Open *UP* (2016.04.14)
addictR1 wrote:here's an update.. just got my extralite stem. was very disappointed...
i ordered a 6° in 80mm.. but they shipped me a 12° instead...
i've waited almost a month for this only to get the wrong part...
also, just feeling it with my fingers, i do notice the edges being sharp and not really smooth. if this 12° would work then might have to use dremel with polish wheel and smooth it out.
I've been considering the 6 degree Hyperstem for a new build. I noticed that Starbike have both 6 and 12 listed but the product description under the 6 degree stem actually refers to the 12 degree version. A bit confusing to say the least, so I'll email them for clarification before splashing the cash. Let us know if they exchange it for you. TA
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
liam7020: i had some email exchanged with starbike.. they've proposed to partial refund me.. but let's see if they follow through on that. i've went ahead and mod the stem and completed my build. 12° seems to be parallel to the ground for my fork that's 72°. i think with 6° slammed, it might still have some rise for my bike, not sure about yours..
- wheelsONfire
PSM wrote:I e-mailed them.
Yes i understand! But as what, an owner with hands on experience or as a dealer?
I ask since i have used this stem and have a story around it.
I feel i have a bit of responsibility in this, "high lighting" the issue and that is why i ask.
It is good this comes out instead of creating doubts of this stem.
I had no intention to cause an issue for Extralite. So i think this is good, that the update is avaible for new customers to see.
Your CAD drawing, is it only showing steerer tube clamping, or does it extend to the handlebar clamping and edges between the two clamps (clamping
handlebar to stem)?
Bikes:
I have this stem, as I mentioned earlier in the thread.
I have just checked the steerer clamping area, as well as the handlebar clamping area on both the main body, and the two front pieces.
All parts have angled edges, just like in the 3D drawing.
Mine?
I bought it in October this year, so about a month and a half.
