What power meter would you choose?
Gardengnome
by Gardengnome
Hi
I have been searching and researching about power meters for a while. Looking for one that will work on my winter bike, that has Shimano gxp and my summer bike that has Sram red22 bb30
The 2 power meter i have been thinking of are the powertap P1 pedals or converting the winter bike and using rotor IN power. Any thoughts or advice anyone can offer?
BRM
by BRM
I would choose . . . . a better matching title, so readers can see where this topic is about without opening.
:roll:
Gardengnome
by Gardengnome
Sorry didn't really give it much thought!
poppiholla
by poppiholla
Rotor Inpower
Specialized Tarmac S-works SL7 (Satin carbon spectraflair tint)
Specialized Tarmac S-works SL6 (Green Cameleon)
Specialized Tarmac Pro SL6 Disc (Blue/Teal Sram Force AXS)
Specialized Epic Elite 29
Greetings from the Netherlands
cobrakai
by cobrakai
Why don't you get a power2max with rotor crank? Same crank but power from both legs and a lower price to boot.
LocoDuck
by LocoDuck
+1 on power2max.
Gardengnome
by Gardengnome
Will the power2max still work on a bb30 frame and a gxp frame?
rainerhq
by rainerhq
"Nothing compares to the simple pleasure of a bike ride"
Gardengnome
by Gardengnome
Sorry I have been looking just need to get an adaptor for the gxp frame was just worried the spindie would be to short when switching
wjs
by wjs
I do not fully understand the chart. Will it work with a bb30 gxp setup? Thx
Verzonden vanaf mijn iPhone met Tapatalk
cobrakai
by cobrakai
Here's rotors compatibility chart
https://www.google.com/url?sa=t&source= ... JH6JGzsZYQ
So bottom line is both the 3d and 3d+ are compatible with both, assuming appropriate bottom bracket selection
RyanH
by RyanH
Just a point of clarification: gxp is sram's name for it's bottom bracket/24mm spindle cranks.
I would advise getting a used Quark. You can get one for 700 or so on eBay right now and you'll get both left/right power plus a good crank in itself.
Sent from my VS986 using Tapatalk
jamesbass
by jamesbass
If it's a pure Weight Weenie decision:
- Stages only adds 20g to the crank
- use smartphone app to record data as you won't need to add a head unit to the bike
If it's a performance decision and you wish to see data as you ride:
- Stages 1-leg system wont be the best for data & you'll never truly know your imbalances. Worse, once you realize this, your imbalances may radically change due to subconscious overcompensation.
- SRM wired systems are known to be bombproof and reliable almost forever. I know many models circa 2005 that are still in use now and it'll hold up fine as long as batteries/calibration are kept on top of. Dead cheap 2nd hand if you use the Google wattage group or check eBay.
Gardengnome
by Gardengnome
Can't believe how cheap the fsa version of the power 2 max is very tempted to get that now
wjs
by wjs
Thanks! Just finished ordering a power2max!
