What tubular with great puncture resistance ?
muntos
by muntos
Hi,
I'm new to tubulars and for the beginning I'm searching for a very good puncture resistant tubular tire as I'm a little bit afraid of making flat on a tubular (or at least I want to avoid it as much as possible) with decent/good rolling resistance and weight (under 290 gr).
My choice would be 25mm wide.
At this moment I found Vittoria Pave CG, Veloflex Arenberg and Continental Gatorskin...
What are your recommendations ?
Marin
by Marin
If clinchers are an indication, anything from Conti. Ride won't be as good as the alternatives though.
My recommendation would be to use a light clincher :D
natefontaine
by natefontaine
I've found the regular Sprinters to be better than gatorskins, Competition also has been doing well. I prefer the extra grip for some light service road rides with the Competition up front. I'm ~65kg, run 60f-75r on 25mm with the Sprinters and 50 mL of OrangeSeal in each tire. I just retired the rear with over 6000 km and not once did it ever go flat on a ride. The front had one puncture flat because I forgot to add sealant after 2 months of summer use, added sealant and it's still going strong after 4000 km. I've got a Corsa CXIII on the rear now, we'll see how that goes.
Conti Sprinter gatorskin @ 25mm.
The ride quality is almost... bad but at lower pressures it's tolerable.
russianbear
by russianbear
Vittoria Corsa Elite in a 25 perhaps? Good price, butyl tubes, decent ride according to the internets.
Spincycle
by Spincycle
Vittoria Pave CG is a good tire
boysa
by boysa
kgt wrote:Conti Sprinter gatorskin @ 25mm.
^What he said.
They aren't the smoothest or most supple, but they are durable. I think it will also depend on what wheels you are gluing them on. I have a set of 25mm glued to some HED Belgiums and I run them 85R/70F. The ride isn't too bad at all. Since I'm putting in serious training miles, and doing a lot of interval work, it's more important to me to avoid punctures than a slight drop in ride quality (at least for this particular set-up).
FWIW, I also find the tubular version to be a much better tire than the clincher.
"Deserve's got nothing to do with it." William Munny
muntos
by muntos
Well I do look for a quality ride as much as possible as I understood that with Scott Foil frame the ride is quite harsh and I don't care so much for durability. The wheels will be Bontrager Aeolus 3 D3
boysa
by boysa
Vittoria CG are not a bad option. You won't get as many miles as the Gatorskins, but ride quality is improved. Might look for them now, though, as I'm not sure if Vittoria is continuing the model. I haven't studied their new line, so perhaps they have something replacing it...
boysa
by boysa
In addition, I have found their SR to be a nice tire. MUCH better grip than older versions, 24mm wide, decent lifespan.
ultyguy
by ultyguy
If puncture resistance is your no 1 goal, there is only one option, Gatorskin. The other upside is that they are super grippy. The ride quality is ok as long as you're not expecting 25mm latex tube plush.
lannes
by lannes
Aging will help the durability of tyre like the vittoria and challenge brands
http://www.cxmagazine.com/buying-tubula ... -explained
superdx
by superdx
Give Michelin Pro4 tubulars a try. The compound material is pretty much what's in the Service Course tires, and those have been consistently reviewed as having great puncture resistance along with low rolling resistance.
Conti Competitions are quite reliable but the ride is beyond harsh. I've punctured those too. After I use up my last backup tire, I will be switching permanently to Michelin.
Jmdesignz2
by Jmdesignz2
I mentioned in another thread that tubular punctures can be mostly avoided by periodic brushing and inspecting tires for debris. Also being vigilant and aware of road debris :)
mrgray
by mrgray
in my experience veloflex and vittoria ride like pillows but offer almost zero puncture protection. but if you brush the tyres as per above and get lucky, it can work out. sealant (tufo extreme) is a must have. or improve chances of no puncture even further my sabotaging ride quality and use schwalbe ones, or sprinters etc.
and always carry sealant, a pump and a spare.
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR :D
