Cold weather riding and shoes!!
- wheelsONfire
It's getting cold and i am using overshoes.
I have contemplated beefed up shoes, but i am not sure if this is so much better than using the standard shoes and an overshoe?
I use Giro Factor (46½ and 47) and i have no clue on what brand is alike?
Mavic? Northwave?
Often use a bit longer shoes due to issues with toe box!
Mavic? Northwave?
Bikes:
Open *UP* (2016.04.14)
- Samuel Sanchez Gonzalez
Check on eBay there are plenty of Lake CX145 winter high quality shoes in wide fit if you need a roomy toe box.
You won't feel the need of overshoes.
http://www.ebay.fr/itm/Lake-CX145-Winte ... NIM7YVsScA
Last edited by Samuel Sanchez Gonzalez on Mon Oct 26, 2015 10:44 am, edited 1 time in total.
For Winter Riding I use Lake MX303's. They're far superior to shoe boots. The only negatives are they weigh a bit more, but honestly who rides their fastest in the winter anyway? I find the work great down to the low 20's. If the temperature drops below that its necessary to add chemical toe warmers. If you're really a Rule #9 guy then for the really cold days you need to get Wolvhammers
Colnago C-59 (Dura Ace)
Firefly(Ultegra)
Colnago C-64 disc(ultegra) with Bora 35 wheels
Firefly(Ultegra)
- bikerjulio
My Louis Garneau winter shoes were excellent through Toronto winters. They make a good quality product at a very reasonable price. Buy one size larger to fit thicker socks.
http://www.louisgarneau.com/ca-en/produ ... LING_SHOES
There's sometimes a buggy.
One.
One.
I have had excellent luck with a similar setup to CBJ in temps as low as 10F: I wear a wool sock, toe warmer if absolutely necessary, regular cycling shoes and the gore thermo road shoe covers. The thermo cover is made of gore-tex and has some padding inside to slow the temperature transfer from the outside in.
TBH, every year I end up looking at heated insoles for the wife, every year the weather turns good just as the shops start to have them in stock again!!
She uses the Northwave artic boots AND thick neoprene overshoes.........
I have used Northwave Celcius Arctic GTX (or something like that) for a few years, my feet stay warm enough. The mtb variety.
If you have a lot of water running down your legs you want a variety that goes down far enough so that the water does not run into the shoe.
If you have a lot of ice and snow I'd actually consider flats and some shoe with a good grip for commuting, where you have to put down your feet alot.
CBJ wrote:One thing that suck with my setup is the time it takes. It would be my faster just to be able to jump into a pair of nice winter riding boots.
If you skip on the neoprene overshoes and just pull on the gore thermal shoe covers, it will take no time at all. The thermal overshoes you just slide right in and velcro at the back. 15s per shoe max. They are excellent
rideintospace wrote:CBJ wrote:One thing that suck with my setup is the time it takes. It would be my faster just to be able to jump into a pair of nice winter riding boots.
The Gore I have is not the Thermal it's the Windstopper Overshoe Light.
