Bontrager Speed Stop Brakes
The front should fit just fine (they use the direct mount standard), however I'm not sure about the bottom bracket mounting brake, I would imagine something would get in the way hence why the shimano direct mount callipers have a more central pull design at the BB.
On something like a canyon aeroad where the rear brake is on the seatstay bridge I'm 99% sure they would both fit.
OliverRB wrote:However I'm not sure about the bottom bracket mounting brake, I would imagine something would get in the way hence why the shimano direct mount callipers have a more central pull design at the BB.
I think this will not be the problem, if it can be bolted and the brake shoes are possible to adjust that they will fit the rim I think it will fit.
I hoped somebody had fitted them on a other bike then a Trek....
Are you talking about the Emonda brakes? They're both built around the direct-mount standard, so you should be fine.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
I was informed by a dealer that these brakes are not compatible with the Trek Madone 7 chain stay mount. Don't know why, but it might be a similar problem on the DeRosa.
Check out the FSA direct mount brakes, I'm very happy with mine. Not the lightest, but not a fortune and the clearance all around is excellent
