Speedplay Ti spindles off ebay & actual body rebuild kit....
Dudes,
I am trying to figure out pedals for my new build. I want ti speedplay zeros and if I wanted to save money could I buy ti spindles off ebay and buy a body rebuild kit from the company/bike shop. I'd would save over $100 if I did this and the ti spindles I've seen on ebay come in lots of colors.
Does this make sense at all? Has anyone done this?
Thanks fellas.
Thanks fellas.
It does make sense and I'm sure someone has already put aftermarket ti spindles in their pedals!
You could also buy the cro-mo version and upgrade with ebay spindles. The cro-mo version might be cheaper as a rebuild kit. This is what I've done : 100€ for the pedals and around 50€ for the spindles.
Current bikes:
Scott Addict Premium Disc 2018
Scott Addict Orica Greenedge 2015
Retired:
Canyon Endurace CF SLX 2016
Canyon Ultimate CF SLX 2013
Retired:
There is tons of info on this forum about Sp**dplay and after market spindles.
Search on Ward (Industries).
Most titanium spindles are made of medical titanium. That is not the strongest titanium.
Ward uses a titanium specially developed for militairy planes. A fraction lighter and at the same time stronger.
Also you will find an extensive guide how to change the spindles.
And you also will find information of a guy that was threatened by Sp**dplay lawyers because he sold maintenance sets on ebay and used the name Speedplay.
Tispindle.com or titaniumspindles.com
(formerly Ward Industries)
Hehe...lots of internet hate directed at Specialized for protecting their rights but the Speedplay lawsuit thing for aftermarket interlopers is really something. I am a big fan of Speedplay and ride zeros with stainless steel spindles but haven't gone the Ti spindle route where there have been more reported failures.
I used titaniumspindles.com and would recommend them, great communication. they had a few different options when i emailed them.
I bought a pair of standard Chromo Zero's and replaced the spindles, reducing weight from 226gm to 164.
You also get the additional choices of colours with the chromo zeros over the body kit which i was only able to get in black.
All in i spent £120 GBP.
i've got two sets with Ward spindles. i had a CroMo original and Stainless...both converted. had them for some time now when they were Ward...i have since gotten a rebuild kit from Excel Sports and replaced the entire lollipop. good stuff and less money going that route you mentioned.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Ward spindles all the way but you need to email them as they don't publicise the prices online for the SPlay spindles - I've got two sets of them. I wouldn't bother with the eBay versions. Also depending on where you are located at the moment Matt dulight.fr sell the ward spindles as well, they list online they are manufactured by Dulight http://www.dulight.fr/index.php?cPath=95_62_133 but they are Ward Industries
I started to get a lot of rocking in the system. I run the zero pedals. On the plastic i could no longer see the L&R or dimples on the pedal. Worn that much. New pedal bodies and its good as new.
joshclick wrote:nickf how do you determine when you need new pedal bodies? Mine are starting to look pretty worn, but there still might be many miles of life in there.
nickf wrote:I started to get a lot of rocking in the system. I run the zero pedals. On the plastic i could no longer see the L&R or dimples on the pedal. Worn that much. New pedal bodies and its good as new.joshclick wrote:nickf how do you determine when you need new pedal bodies? Mine are starting to look pretty worn, but there still might be many miles of life in there.
also, i change the cleats before i change the pedal bodies. the inside of the cleats where the pedal sits gets worn as well.
- Factor LS Disc
- Factor LS Disc
