Edco Monoblock Cassette & Campagnolo
- ultimobici
- in the industry
- Contact:
Just saw this http://edco.ch/products/accessoires/monoblock.html
The 11-32 for Campagnolo interests me for big days in the mountains.
Has anyone successfully tried a 32 with Campagnolo? If so what hanger measurement do you have and what chainrings were you using?
- bikerjulio
I have seen several threads where people were using shimano 32t cog successfully with an otherwise Campy drivetrain. No personal experience, except I know the "old" RD's handle a 30t cog just fine, and the newer RD's were supposed to have a little more clearance.
There's sometimes a buggy.
One.
One.
- bikerjulio
One.
One.
- arizonahalfnhalf
Glad you posted this! I have been thinking about an 11-32 cassette on my campy drivetrain. I hadn't seen these Edco 11-32 in the campy version. I've heard good things about the edco cassettes!
But yeah, there are multiple threads on the boards with testimonials saying the 11-32 combo works well with the campy short cages.
I'm also thinking of getting an Athena-11 triple rear derailleur (longer cage) and trying a 11-36 shimano cassette.
- ultimobici
- in the industry
- Contact:
arizonahalfnhalf wrote:Glad you posted this! I have been thinking about an 11-32 cassette on my campy drivetrain. I hadn't seen these Edco 11-32 in the campy version. I've heard good things about the edco cassettes!
I think the 36t will be a little too much. The Athena triple mech is only a longer cage not a different geometry mech. So it will be no different to the rest of the range in terms of maximum sprocket size.
- bikerjulio
There is not a black or white answer to this question as Ulti alluded to in his OP.
Firstly, the long cage does not buy you any additional upper sprocket clearance, just adds chain wrap capacity.
But hanger dimensions are a variable between bikes, and you will see that Campy for instance specs a 4 mm variation as OK. So depending on your bike's hanger dimension, a 36t sprocket might just work if the hanger is at the long end of spec.
One.
One.
The edcos are machined from a solid block of steel, like the RED cassettes.
- arizonahalfnhalf
To follow up on this, simply as reinforcement to what is already known, I mounted up a mate's wheel with a shimano 11-32 cassette on my 2015 Super Record grouppo and it couldn't run more smoothly. The big-big combo is too much, though, that would need to be avoided. With my setup, its not tight enough to rip the derailleur off I don't think, but not good either way and no reason to be in that ratio regardless!
I appreciate the input, genuinely! Was kind of wondering if it was a stretch, but was going to find a friend with a spare 36 cassette and give it a whirl.
bikerjulio wrote:There is not a black or white answer to this question as Ulti alluded to in his OP.
ultimobici wrote:I think the 36t will be a little too much. The Athena triple mech is only a longer cage not a different geometry mech. So it will be no different to the rest of the range in terms of maximum sprocket size.
- bikerjulio
arizonahalfnhalf wrote:I appreciate the input, genuinely! Was kind of wondering if it was a stretch, but was going to find a friend with a spare 36 cassette and give it a whirl.
Give it a go on the stand and be careful in the big - bigger combinations.
You will need to back out the "H" screw on the RD for max clearance if you haven't already done so. Check instructions if not sure.
The total chainwrap capacity of a Campy short cage RD is in the 32-33T range. If your drivetrain exceeds that then it's safer to size the chain for the big-big combo and sacrifice a few small gears while on the small chainring. At least no damage can accidentally be done.
And as an aside, i realized a while ago that when Campy spec. max sprocket for the RD, they don't state the theoretical max, they state the biggest one they currently make as being the max.
One.
One.
- ultimobici
- in the industry
- Contact:
That's a setup that Campagnolo made in triple form until recently.
How was it on the Mortirolo? Didn't have time (or legs!) to do it this year.
- Location: United Kingdom of Great Britain and Northern Ireland
I'm a moderately fit 47 year old ... was never going to do the Mortirolo on a double with a 34 inner no matter what the cassette on the back.
There are a number of 'tripleizer' chainrings out there in BCD110 format, but none work as good as the IRD ones. I dislike the regular 130/135BCD triples.
As I am sure you know, there is a difference in slogging up a steep hill/mountain and riding up it with good cadence.
