FSA Team Chain vs Dura Ace Chain
ParisCarbon
by ParisCarbon
Taking the switch over to Di2... going to be running an FSA K Force SRM.. question is.... the chain.. saw both the Tinkoff and Etixx teams are using the FSA chain vs the Dura Ace chain.. does this have anything to do with them using the FSA chainrings vs the Dura Ace? Garmin guys also using FSA rings on the SRM, but using the Shimano chain??
davidalone
by davidalone
It has nothing to do with the FSA chainring and everything to do with the fact they are sponsored by FSA.
The DA chain is probably better.
Philbar72
by Philbar72
def sponsored kit. i'd go KMC myself...
ParisCarbon
by ParisCarbon
K thanks guys..
On a sidenote, was the reason why Etixx was having so much shifting issue in the spring ever determined?
aaric
by aaric
Philbar72 wrote:def sponsored kit. i'd go KMC myself...
KMC chains are narrower than shimano. And the documented Di2 adjustment relies on the width of the chain to set its position. If you setup a KMC chain on a di2 bike as documented, it won't shift properly towards the high end of the cassette. I've tried adding extra clicks of adjustment, but never could get it to shift as well as a shimano chain.
MisterMuncher
by MisterMuncher
FSA chains, from my limited experience, are KMC chains in all but name, down to the identical quick link.
gmakris
by gmakris
Go with DA chain if you are using shimano cassette. It will work better
mulletmaster
by mulletmaster
I've never heard of the chain width discrepancy. Seeing as kmc don't make any other group set components it doesn't make much sense to me that there would be one. Anyone a link to proof of the above?
madcow
by madcow
Kmc chains work great on Shimano. There is no difference in width between Shimano and Kmc chains, both are 5.62mm. Campag 11 chains are a bit narrower at 5.5mm.
