I ordered the bearing from the amazon link above. It came with a set of 2 but they re the same size, which only fit the top bearing. Am i missing something. I actually need the bottom one. Can anybody tell me where to buy the bottom bearing?
Sent from my SM-N900T using Tapatalk
Scott Foil Headset Bearing
Apparently, Scott foil uses a tapered steerer tube, hence the bottom bearing is bigger than the top. I'm sorry, I assumed they were the same as the Addict since the numbers you posted matched the ones I bought a couple months ago. I'll do some research and see if I can find the correct dimensions.
I purchased a 2011 Scott Addict RC on ebay and it didn't come with a headset but already has the headset cups installed. What can I get that will work? I've tried syncros, FSA and Ritchey with no luck. Original spec is Ritchey WCS LOGIC ZERO PF 28.6-44-50 H=12.9. I need the bearings, dust cover, split ring and crown race for the fork.
Thanks
Thanks
