Cannondale Supersix - Headset Bearings
toshi
by toshi
The cartridge bearings in my 2010 Supersix are done, and I've been trying to find replacements without purchasing the entire $90 assembly from Cannondale Experts. The bearings are not proprietary so I'm trying to nail down specs.
Not even Cannondale support can tell me what the bearing dimensions are. :faint:
Here's what I have been able to determine from past postings, and by looking at the cartridge bearings themselves (the etched numbers on them are worn off unfortunately).
top cartridge bearing
1-1/8"
45deg/45deg
6.5mm tall
lower cartridge bearing
1.5"
45deg/45deg
8mm tall
This may be a longshot but hopefully it is helpful to someone in the future, even if no one has a definitive answer. Any insight appreciated!
Calnago
In Memoriam
by Calnago
A guy brought his Cannondale over complaining about his steering. The previous mechanic used a normal height lower bearing, which clearly doesn't work, then to take up the difference he put a big huge washer on TOP of the crown race, between that and the bearing. Crazy. Anyway, I faced the same dilemma as you and despite trying to track down just the stuff I needed I ended up having to purchase the entire headset system from Cannondale Experts. I can't tell you what the exact dimensions were but you're certainly in the ballpark with the numbers above.
toshi
by toshi
Thanks Calnago! Washer on the crown race, yikes!
toshi
by toshi
Updating this with dimensions:
ID x OD x WIDTH + ANGLE
upper cartridge bearing
30.15mm x 41.8mm x 6.5mm 45°x45°
40mm x 52mm x 8mm 45°x45°
