Speed Sensor for Cateye – WW options?
I am searching for a small light weight ANT+ speed sensor compatible with a Cateye Stealth 50. I would like to keep the mount as clean as possible. At http://www.thisisant.com/ I see that there are 141 compatible products. Any WW advice?
1956 Rudge Sport
1994 Carbonframes Tetra Pro
(re-branded to Calfee 2006)
2010 Trek Top Fuel
2015 Velovie Vetta
2020 OPEN WI.DE.
2010 Trek Top Fuel
2015 Velovie Vetta
2020 OPEN WI.DE.
I think there was a topic recently but can't remember the title....anyone?
When I was looking for a new speed / cadence sensor one of the things I wanted to do was the same as you, to have a nice, clean look when finished. I ended up getting the Garmin magnetless speed and cadence sensors. The speed sensor wraps around the rear hub. The cadence sensor on the crank arm. Both do so with industrial rubber bands. While not completely invisible, the whole thing looks a whole lot cleaner than it did beforehand.
Both are "set and forget" items. DC Rainmaker's review of them is here: http://www.dcrainmaker.com/2014/05/garm ... nsors.html
Personally I've been very happy with them and it's a purchase I definitely do not regret.
i've been using a vdo z-sender for 5+ years, absolutely no issues, many many cold wet rides, also quite a few 30-50 celsius, it's still on it's second battery
i stick a small neodymium magnet on the spoke, 5x5x2mm is fine
http://www.rosebikes.de/artikel/vdo-ant ... aid:484428
i've seen the same unit resold under other brand names
micky wrote:I think there was a topic recently but can't remember the title....anyone?
yes there is a similar thread looking for a cadence sensor for a Garmin
1956 Rudge Sport
2010 Trek Top Fuel
2015 Velovie Vetta
2020 OPEN WI.DE.
2010 Trek Top Fuel
2015 Velovie Vetta
2020 OPEN WI.DE.
EvilEuro wrote:I ended up getting the Garmin magnetless speed and cadence sensors. The speed sensor wraps around the rear hub.
Yes I like the Garmin unit.
The ANT+ list for Cateye Stealth 50 does not show the Garmin as compatible.
However, the ANT+ list for the Garmin Speed Sensor does list the Stealth 50 as compatible.
So go figure.
1956 Rudge Sport
2010 Trek Top Fuel
2015 Velovie Vetta
2020 OPEN WI.DE.
2010 Trek Top Fuel
2015 Velovie Vetta
2020 OPEN WI.DE.
