Post new topic Reply to topic  [ 27 posts ]
Go to page Previous  1, 2
 Post subject:
PostPosted: Wed Mar 03, 2004 3:31 pm
MantraPro wrote:
It's too heavy :twisted:
Here are the specs on one;
New Scandium ISIS Drive BB
-CNC machined hollow Scandium spindle with 7075 X-Long™ Bolts
-Carbon body, alloy cold forged cups
-2pcs High Rolling sealed bearings
-108mm ISIS Drive for Double
.68xBSA 1.37"x24T, R/L cups
.Chainline: 43.5mm
.Weight: 118g (108mm,w/o bolts)
Ride lightly!
 Post subject:
PostPosted: Wed Mar 03, 2004 3:41 pm
:shock: Are you sure? Only 118g!!!!
I want it!!!!!
Ciao Zauri
 Post subject:
PostPosted: Wed Mar 03, 2004 3:48 pm
I want it!!!!!
Yes I'm sure :!:
Ride lightly!
 Post subject:
PostPosted: Wed Mar 03, 2004 4:20 pm
.Chainline: 43.5mm
sorry but alu and scandium BB scare me, i would like a chromo axle i would rather lose 22g of weight savings and have the stiffness and strength of a chromo axle than to save 22g. anyone with me? AC isis BB is what i am going with all the way.
 Post subject:
PostPosted: Wed Mar 03, 2004 9:38 pm
.Chainline: 43.5mm
I don't think your going to get less strength, and the Al BB would be stiffer because of the thicker walls I think.
The AC still isn't available :!:
Ride lightly!
 Post subject:
PostPosted: Thu Mar 04, 2004 5:22 am
.Chainline: 43.5mm
thicker walls??? its an isis BB made to be a certain size of OD to fit, maybe ID is smaller (thicker) but then you could not use the same bolts, so i would disagree with that. i know the chromo axle is stronger and will outlast the alu. so i do not want to gamble with that.
 Post subject:
PostPosted: Thu Mar 04, 2004 5:27 am
The internal diameter does not dictate the bolts size. The threads that are tapped into the axel can be made any size. It's like a smaller diameter hole is drilled into the BB, then for the treads for the bolts a larger diameter hole is drilled in, but only the total lenght of the threading needed, not the entire length.
MAMA SAID KNOCK YOU OUT! HUH!
 Post subject:
PostPosted: Thu Mar 04, 2004 5:36 am
It doesn't use the same bolts, read the spindle spec. line again.
You can't know that one is stronger or will last longer than the other, no one can unless they tested both.
Ride lightly!
 Post subject:
PostPosted: Thu Mar 04, 2004 5:41 am
but if you drill a bigger thread for the same bolts to fit then it will not have thicker walls, right?
well i know chromo will be stronger than alu and outlast it - but in this case your right a test must be done - but my money is on the AC BB or at least thier spindle/axle.
 Post subject:
PostPosted: Thu Mar 04, 2004 5:47 am
Only where threading is. An aluminum axle is stiffer, which is better and worse. Better, because, well, stiffness is good. Worse, because of fatigue life. But if well design an aluminum axle can be just as good.
 Post subject:
PostPosted: Thu Mar 04, 2004 5:48 am
For the same amount of material, yes it will, but you can put more material in there, which is what they did. Because it's less dense, it's also lighter with more material, that extra material should actually make it stiffer, or the same stiffness, with extra strength.
Ride lightly!
 Post subject: Stiffness
PostPosted: Thu Mar 04, 2004 8:02 am
If the OD is constrained (as it is) then an Al tube will need to be approx 3x the wall thickness of the CrMo for the same stiffness. This will lead to them weighing Approx the same.
Is there enough room inside the Spindle for this to be the case?
I suspect the X-Long bolts on the Road Shark are there to try and prevent flex inside the splines and bearings. A grade 1 Interferance fit thread (light resistance to bolt instalation the whole time) could well act as thicker wall.
I think it is unlikly an Al spindle BB will fail, if designed correctly, but additional flex could cause premeture bearing failure, a problem already common in ISIS. A combination needle/ball would help - but add weight.
Success is how far you you bounce back up after being knocked down
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
Users browsing this forum: 1415chris, Burgunder and 49 guests
There are no new unread posts for this topic. Enduro XD-15 Bottom Bracket?
BdaGhisallo
Mon Apr 15, 2013 7:14 pm
rmerka View the latest post
There are no new unread posts for this topic. Attachment(s) Help, SRM FSA K-force - which bottom bracket?
srasmussen
Wed Aug 29, 2012 8:20 am
There are no new unread posts for this topic. Bottom bracket question
BreakfastClub
11
641
Mon Feb 18, 2013 11:13 am
There are no new unread posts for this topic. Bottom bracket internal sleeves
Stockie
Mon Aug 13, 2012 7:52 am
bobbyOCR View the latest post
There are no new unread posts for this topic. Bottom bracket for Rotor 3D with Power2Max PM
Frankie13
9
875
Fri Oct 26, 2012 8:30 am
madmole View the latest post
It is currently Thu Jun 20, 2013 10:24 am
