Should I still worry about the 2012-13 Specialized recall?
I will add one question. Does it also apply to Allez framesets that came with same (or not the same) forks?
http://specialized.com/OA_MEDIA/pdf/121 ... ecteur.pdf
Recalls, at least in the US, are never dependent on being an original owner since they are a safety issue rather than a one-off defect.
i'm so tempted to simply respond, hey, look everyone, evolution in action
but that'd be a bit harsh, so to be clear...
if a bike is listed by spesh as covered by a safety recall then follow the recall procedure as this may save you from screaming death
worst case, it's already been done, they'll find the record of this, and you wasted a bit of time
you may well be able to check by contacting them direct with model+serial number
