Fast dad is at it again bar/stem combo
BmanX
by BmanX
awesome work. I love this stuff.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
FastDad
by FastDad
Next step...the stem body
At first I did try some thick paper for a organic shape, but this does not work well while covering it with carbon and resin.
...it was deformed
So I did listen to some friends and used Styro foam...but did not follow the general round shape ;)
FastDad
by FastDad
first layers of carbon
At first I used some layers of carbon wattled tube. It´s against the torsion.
At the area of the screw I pulled away the carbon filaments and placed a little "tube" I made before. This way I do not need to drill a big hole there and effect the stiffnes in a bad way.
(head of screw with some tape ti mace the diameter a little bit wider)
As you can see, I wraped the edges of the carbon tube across the bar and the fork tube.
After all is satured with resin I wraped it with tear of tissure and tape
24h later
That´s not all
kevosinn
by kevosinn
So great to have you here thank you for posting!! I follow what i can on the light bikes forum.
FastDad
by FastDad
Not sure if I can help you, but I will try...just drop me a mail or pm
FastDad
by FastDad
main layup
In my case I need some UD 0° along the fork tube, some UD 0° along the stem and a good amount of rovings wraped from the tube, the stem, to the bar, back to the tube and so on.
Sleep well my little Frankenstein
calvin
by calvin
Realy looking forward to see the end result
FXKalvis15 code at @montonsports
FastDad
by FastDad
every time I pull it of it is like Christmas :mrgreen:
Now it is time for the final top layer, but at first I need to sand of the folts (or you can fill them with some filler)
I made a carving pattern out of paper,...
...sprayed a sheet of carpon tissue with glue,...
...transfered the shape of the carving pattern and...
attached the carbon to the combo.
Now it is time for the epoxyd resin and some serious amount of tape
Haydn
by Haydn
Really cool to see all the steps, great work!
FastDad
by FastDad
I do also like step by step instructions...so that´s the reason I show it this way
FastDad
by FastDad
tomorow I will show you more details
jeffy
by jeffy
impressed.
calvin
by calvin
Are the big manufacturers making their carbon products the same way?
FastDad
by FastDad
I know a manufacture who does it very simillar (positiv way of layup), but the big names will work with moulds (negative and pressure tube inside). With the moulds they have much better surfaces and they can reproduce on a higher level of "look a likes"...way to expensive for a me
Frankie - B
Admin - In the industry
by Frankie - B
Wow, great work FastDad. Good to have you on board.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!
