Fast dad is at it again bar/stem combo
AZR3
by AZR3
This is the stuff I love to read about on WW, excellent job!
bici1977
by bici1977
That is probably the unsafest construction I have seen, in like forever! I would never trust my life on such a construction! Even if it doesnt crack after the first 100 miles, its probably flexy as hell.... way to ruin a handle bar.
Jengaback
by Jengaback
This is proper weightweenieing. Not just buying a exotic 5k frame and populating it with another 10k of exotic parts with zero tuning. Love this
xena
Banned
by xena
Jengaback wrote:This is proper weightweenieing. Not just buying a exotic 5k frame and populating it with another 10k of exotic parts with zero tuning. Love this
:thumbup: Otherwise being a WW would be for the well off.
FastDad
by FastDad
Thanks a lot :D
This is, what keeps me rolin...especialy since I can´t invest this kind of money into parts :beerchug:
Already I used this combo for nearly 200km. Nothing is broken till now, it doesnt make any noises and the flex is less then a F99
peel off
fresh shed
with some sanding
a friend had a nice idea...who discover it at first?
FastDad
by FastDad
but the M6x15 screw is missing on the scale
danbjpa
by danbjpa
Clean combo and nice rectangular stem shape like Look C-stem.
Any special reason that you maintains this steerer tube excess?
Enviado do meu iPhone usando Tapatalk
nobuseri
by nobuseri
Clean bar/stem buildup and end result. Clean bike, too. :beerchug:
Much props for the custom work and insight. :thumbup:
Cicli Barco XCr Road
Moots VaMoots
Parlee Z1
SuperX Hi-Mod Disc
2old4this
by 2old4this
Work of art. I am envious ...
FastDad
by FastDad
danbjpa wrote:Clean combo and nice rectangular stem shape like Look C-stem.
I just can´t decide to cut it off right now...this would be something final and I have no chance for changes anymore
FastDad
by FastDad
I´m not sure, if my words about the amount of flex came out like it should be...there is no noticeable horizontal flex and even the torsion is ok for me. A Syntace F99 has more flex and is softer then this combo.
I know that the clamp position is not the best and that it is not as strong as a regular type of clamping a stem, but it holds the position on regular roads and riding. Also I can not rotate the combo on the steerer tube. On bumpy roads the headset loosen a little bit, but this is ok for me...the combo is not made for "Paris-Roubaix" ;)
kevosinn
by kevosinn
What type of tape are you using there?
FastDad
by FastDad
It´s a high elastic electricians tape .
briantumma
by briantumma
When you've epoxied the carbon in place, do you just wrap that with the tape or do you have another layer inbetween to stop it sticking? This whole thread is making me what to have a go - very inspiring!
FastDad
by FastDad
while processing I compress the carbon with some layers of tear-of-tissure and fix this with the elastic tape...as you can see here
For the top layer I used the tape only. I fixed the end of the tape a little bit outside the "working area" and pulled it over the carbon then.
