Calibration value returns zero in my Garmin Edge 510
clm2206
by clm2206
Hello,
I've just changed my SRM batteries, and after triggering the PM my Garmin was able to read everything about the PM (ID, slope, and every detail about battery status, software version, etc) but fail to calibrate, returning a zero value!!! I'm scared, I have now a very expensive cadence sensor.
Any thoughts?
pdlpsher1
by pdlpsher1
I'm not familiar with SRM power meters however my Quarq can return a calibrate value anywhere from -110 to +20. So in theory a zero is a valid number. What was the previous calibrate value? Could you try another Garmin to see if it could calibrate it?
clm2206
by clm2206
No, that's not the case. Normal values are between 200 and 900, SRM states that values above por below this interval are wrong.
Reason: Deleted the quote.
ghisallo2003
by ghisallo2003
Are you sure that your Garmin settings have not changed. I would look for update from Garmin updater, and then make sure that you are not looking at an automatically zeroed figure.
clm2206
by clm2206
Not the case either. No settings changed and software is the latest v4.20 ... Maybe it's a software bug, pm was out when I upgraded from Garmin ...
Reason: Deleted the quote. Not really needed.
ghisallo2003
by ghisallo2003
Are you sure it is not the torque that it is reading and zeroing ?
Garmin have gone through a change from displaying offset to torque.
clm2206
by clm2206
Garmin have gone through a change from displaying offset to torque.[/quote]
No, there are two power measures I display, the 10s avg power and % of FTP power, and both read zero ... helpless ...
The real problem begins at the time I try to calibrate te pm, when it reads zero. Besides that, all data is apparently normal.
Reason: I could repeat the sentence above, but I could also tell you that I have cleaned the post.
ghisallo2003
by ghisallo2003
cadence?
clm2206
by clm2206
Cadence is ok, the only issue is when I try to calibrate the pm
Reason: You know what? I'll clean this one as well ;)
clm2206
by clm2206
My pm is on the way to Boulder, CO. Hope that fixing up the stuff doesn't cost me an eye.
Frankie - B
Admin - In the industry
by Frankie - B
@clm, please use the button right next to the one that says "quote" on it. the one you should click in the cases above should have been "reply".
Thanks!
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!
clm2206
by clm2206
ok Frankie-B!!
