Valbrona
- Location: United Kingdom of Great Britain and Northern Ireland
by Valbrona on Mon Aug 31, 2015 2:11 pm
Poulidor wrote:..., it would have never occurred to me to leave any space or spacer above the top of the stem. And unless someone convinces me with categorical arguments I never will.
Some might leave the steerer sticking out of the top of the stem a little ~2/3mm and then use a thin spacer above the stem. It means the whole of the stem binds onto the steerer, and some might think that this is 'preferable'.
kode54
by kode54 on Mon Aug 31, 2015 2:21 pm
i've seen fork steerers crushed because of too much clamping of the stem or because the star nut is below the stem clamping area. i always use a torque wrench with carbon paste, but most shops do not. my friends fork was split due to too much clamping from the stem bolts...and the star nut was around the second clamping bolt. so again, it depends on what type of star nut you have as well. i have a 8mm spacer on top of one of my bikes while the other does not.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
rms13
by rms13 on Mon Aug 31, 2015 3:08 pm
The correct answer is refer to your owner's manual because it varies from one manufacturer to another. My Easton manual said leave spacers above the stem, Cannondale said never leave spacers above the the stem
The argument to leave spacers above is that the stem is completely around steerer for integrity. The argument against (at least with Cannondale) is that the compression plug is adding extra reinforcement and by putting spacers above the stem, you are effectively positioning the stem so the compression plug doesn't extend to the bottom of the stem where the most force is being applied and therefore creating a weak spot where you need it reinforced.
But I would trust specific manufacturer's opinions (if they have a suggestion) since they have done R&D
Delorre
by Delorre on Mon Aug 31, 2015 8:10 pm
Thx all for the answers
To be honest, on my Canyon, I've been running without any expander and only with the hollow Canyon topcap without any issues for more than a year. Nothing exploded or something like that
Currently, on the Addict, I still have the geniune Scott expander that provides a lot of support to the steerer. If I used that as definitive solution, I would cut the steerer 1 or 2 mm below stem and done. But the plan is to swith to an Extralight Ultrastar expander. Does that change anything? I could adjust it flush with the top of the steerer, providing some support, as with the current setup. Or am I wrong?
Valbrona
by Valbrona on Mon Aug 31, 2015 8:41 pm
Delorre wrote:. But the plan is to swith to an Extralight Ultrastar expander. Does that change anything?
It will probably void the warranty, that is all.
rms13
by rms13 on Tue Sep 01, 2015 3:49 am
Delorre wrote:Thx all for the answers
With no expanded how are you preloading the headset?
Tau
by Tau on Tue Sep 01, 2015 6:22 am
rms13 wrote:Delorre wrote:Thx all for the answers
It's Canyon's Acros I-Lock headset ?
Lähetetty minun D5803 laitteesta Tapatalkilla
Delorre
by Delorre on Tue Sep 01, 2015 7:18 am
It had a Synchros I-lock, but ordered that flat topcap + expander from Canyon. I simply adjusted the headset, rode a few 100 miles, re-adjusted it slightly, and than simply removed the whole expander thing. Never loocked back at it
glepore
by glepore on Wed Sep 02, 2015 1:56 am
I honestly don't think its an issue so long as the top clamp bolt is a couple mm below the top of the steerer and you use a torque wrench on the bolts. I really like the little bontrager one for this application as you don't have to pull out the torque wrench and set it, its just like a hex key with a 4nm torque setting built in.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.
; Anvil Custom steel Etap;1996 Colnago Technos Record
shimmeD
by shimmeD on Wed Sep 02, 2015 2:26 am
I'm a weight weenie. I cut my steerer as short as possible, use a 1-2mm bottom spacer, use a handlebar end cap wrapped with a bit of tape to fit, and put the removed expander and top-cap in my toolbox at home. Looked at from another angle, the weight saving could go to another spare tube.
A mate has followed suit. He's not a weight weenie, just a minimalist: he doesn't need the limit screw on his front deraileur after adjusting the length of his cable so that he never drops a chain, let alone a chain-catcher.
Less is more.
Poulidor
by Poulidor on Wed Sep 02, 2015 4:42 pm
mattr wrote:Yes, you are doing it wrong, if it's flush, you can't preload the headset properly.
And the discussions for and against leaving the steerer proud of the stem are already up there.
Most likely you are perfectly correct. However. I'm referring to King and Campagnolo headsets only. I have never, in at least over a decade and many miles and bicycles, had an issue with a stem/headset/steer tube installation. That said, it might be that I cut the top of the steer tube short enough from the top of the stem to make it work.
In any case, I'm pleased not to have had a problem because I don't like the look of spacers over the stem.
bikerjulio
by bikerjulio on Wed Sep 02, 2015 5:58 pm
Poulidor wrote:mattr wrote:Yes, you are doing it wrong, if it's flush, you can't preload the headset properly.
The issue under discussion has nothing do do with the brand of headset being used. Please pay attention.
