Aero crankset for Cervelo P3 (BBRight)?
Any recommendations on an aero crankset. Yes I know it is marginal gains. I am ok with marginal gains. Just like the way they look better than an open chainring. Seen the Rotor Flow as well as used Zipp VumaChrono. Are there any other options? I am a little concerned about the VumaChrono since Zipp stopped making them and not sure how I would go about getting new chainrings when that time comes. What other options would work?
Vision Trimax is another one. Campy has on as well for $$$.
http://alden-designs.com/outer-chainring-covers.html is another, certainly a cheaper option, but may give up a small amount of an already small gain that a dedicated aero crank would get you.
That VumaChrono is quite impressive crankset. Probably what I would go with. The flow isn't bad either. Just depends how much you want to spend.
Just make sure with the VumaChrono that it will fit a BBRight.
