Canyon Aeroad sizing
Hi,
I've been a long time forum lurker, but just signed up.
I'm looking at ordering an Aeroad SLX frameset soon but, as many people seem to be, I'm stuck on which size to go for. The fit calculator on the site says XL but I've been speaking to someone at Canyon via email and they've recommended a L.
Current stats:
190cm tall with an inseam of 90cm (shoeless).
Current set up:
Colnago Master X-Light, size 58 set up very aggressively, with a big saddle-bar drop that I'm comfortable with for long periods. (I'd add a photo for reference but I don't think I have enough posts)
TT: 570mm
BB-Saddle Rails: 810mm
Seatpost extension: 225mm
Stem: 110, 6degree
HT +Headset +Spacer stack: 190mm
Approx. drop saddle to bars: 170mm
All the stats I can find suggest an XL with 110 Aerocockpit and no spacers would give pretty much the same set up, but I can't help feeling I'm missing something.
Any suggestions welcome.
Current stats:
Current set up:
TT: 570mm
Stem: 110, 6degree
- Samuel Sanchez Gonzalez
LoL, are you Ryder Hesjedal?!
Useful numbers missing in your post: -setback and reach will dictate the TT length you need with a correct stem length
It seems you run a short reach (57cm TT with 110mm stem on the 'Nago) but big drop so definitely sounds like the L would be the best for you.
Thanks for getting back to me.
I've got a 3T Dorico inline post with Fizik Arione 00 sat pretty centrally.
The max extension of the Aeroad post is 250mm. Given that the ST on the L is 551, that gives a max. of 801mm - so 9mm less than I currently have. As it's a 330mm post, is running it 9mm past its max from the get-go a bad idea?
9 mm should be fine and not all seat posts are measured the same way .. or use a thicker saddle
Do you often ride in the drop like this or do you spend most of your time on the hoods ?
Are you able to have a flat back and elbow bended when in the drops ?
thanks
thanks
- Contact:
Only Master X-Light I have in the database is from 2006, don't think it has changed in recent years but it could have
Can't find the stem angle of the H11 cockpit - thing to remember is that the bars are a tiny (for normal height people like us) 70mm reach - so your Bar x will likely need to be a bit longer to compensate for the short bar reach.
Plus - for seatpost that 801 should be to the clamp = so 840-850 saddle height to top of saddle.
romalor wrote:9 mm should be fine and not all seat posts are measured the same way .. or use a thicker saddle
thanks
Thanks romalor, I spend most of the time on the hoods but perfectly fine in the drops when required. I've ridden the bike about 3000 miles over the last year without any issues.
cyclenutnz wrote:Only Master X-Light I have in the database is from 2006, don't think it has changed in recent years but it could have
Thanks cyclenutnz, my stem is at -6 and the 420mm Ergonova bars are 77mm reach and 123mm drop, compared to 70/128 for the H11. I'll email Canyon to ask about the angle of the H11 as I can't find a definitive answer.
The XL will feel like a much bigger bike. +15 mm longer front end, +25 mm higher stack.
I would buy the L if you want the feel of a smaller frame. I would not hesitate to run the seatpost a bit longer than its limit.
The XL seems to be a good fit too - no spacers, 110mm is not dramatically short stem but I'd rather ride a shorter frame.
litw wrote:Thanks cyclenutnz, my stem is at -6 and the 420mm Ergonova bars are 77mm reach and 123mm drop, compared to 70/128 for the H11. I'll email Canyon to ask about the angle of the H11 as I can't find a definitive answer.
Did you email Canyon for the angle of the H11 bar and got an answer?
