jooo
by jooo on Wed Sep 30, 2015 6:32 pm
bonafide wrote:djcharlou...No worry about alignment?
What is the Galibier? I am leaning towards an 11X28 with 46 up front, though worried it may not be enough gearing for my girly-man legs on some climbs:)
Col du Galibier
The SRAM CX1 chainrings (and 'road' 1x11 I assume) offset the teeth towards the frame which gives a more central chain-line.
Some crank and chainring combos probably have a better chain-line when mounted in the inner position.
jooo on Wed Sep 30, 2015 6:48 pm, edited 1 time in total.
imax071
by imax071 on Fri Oct 02, 2015 7:04 pm
I use a 44t narrow-wide chainring on a BCD130 crank. Cassette is 10s 11-34 (XT), as the 11s cassettes have either less range or bigger steps. This gives me the same gears I had back in the days, plus one extra climbing gear.
The first ride was mind blowing - shifting is simply up or down, without thinking in front/rear combinations, which also requires memorizing the status.
No dropped chain so far.
steelisreal79
by steelisreal79 on Fri Oct 02, 2015 10:08 pm
imax071 wrote:I use a 44t narrow-wide chainring on a BCD130 crank. Cassette is 10s 11-34 (XT), as the 11s cassettes have either less range or bigger steps. This gives me the same gears I had back in the days, plus one extra climbing gear.
Thanks imax071! And which rear derailler are you using? Cheers for the feed-back!
Verstuurd vanaf mijn SM-G925F met Tapatalk
nayr497
by nayr497 on Wed Sep 14, 2016 4:21 pm
GREAT conversation. I just picked up a modest AL cross frameset that I'd like to turn into a do it all bike (rain, lock-up, commuting, winter riding, etc.). I already have a drop bar bike I use for this riding, going to go with flat/riser bars and rapid fire/thumb style shifters.
Seems like SRAM is the best option for an easy 1x10 crankset. I don't want to go 1x11 so that I can use wheelsets I already have on hand. I don't think I'll have a problem mating a Shimano 10-s RD and Shimano thumb shifter to a SRAM crankset, will I? I guess the only kinda unique thing will be the BB I will need. Thanks.
A good day becomes a better day with a bicycle ride.
xena
- Banned
by xena on Wed Sep 14, 2016 7:14 pm
My next weenie build I'm going I x10. I have put front mech down tube shifters on both my current bikes but I never use them.
I always like having two rings at the front but it is pointless for me. So next build I will be switching to 1 . I use 53/40 x 26 on my guru and 53 /39 x 27 on my trek [ retired ?] I can climb quite easy on my 53 so shall stick with the same set up minus the other ring. I think we will see a lot more of 1 front ring set ups especaily with the long cages. Most normal rear mechs can cope with a 32t just fine.
