wilier Cento1 SR and Zero 9. Any first hand experience?
Zero 9 was slotted under the zero 7. Cento1sr is updated for '16 and no longer has ISP post and has some aero qualities blended in the design. Both ride well. I have some friends on them. The Cento1sr is a higher end setup than the 9 and that's the one I would want.
- vejnemojnen
Zero9 is a phase-out model, no longer available for 2016
- arizonahalfnhalf
What size frame? Was at my LBS talking to the mechanic and there were a few 2015 Zero.7's on the floor. He's a taller guy and noted noticeable flex in the top tube.
He demonstrated by standing over the bike and rocking the handlebars back and forth, bracing the bike between his legs. It was actually pretty alarming how much the size L frame flexed. I could visibly see the top tube flexing from a few feet away. Wasn't the case with the size Small frame. He has noticed it in all of the new Zero.7's he's encountered, not just that one frame.
Albeit, very subjective, but I thought it was worth a mention. No idea as far as comparison to Cento.
To add to arizonahalfnhalf's point, Marcel Wust's review of the Zero 7 in the August issue of Pro Cycling magazine noted that the front end was very flexy. His words: "compared to all the other bikes I have ridden downhill with the same sort of aggression, the Zero 7 displays a tangible lack of stiffness in the front end. The more I pushed it into the corners, the more I felt I had to correct the line."
No idea if that's of any relevance to the Zero 9.
It is true that the newer version of zero7 had worst reviews than the first version which was only praised. The lack of front end stiffness is a common issue to every review.
101sr is otoh a frame already designed a few years ago.
So I don't think Wilier has a model that really worths investing right now.
- vejnemojnen
