Cannondale EVO + Zipp 202 FC + 25mm tires = rub?
grnrcr
by grnrcr
Anyone running this specific combo? I've heard 25mm are fine on narrow rims but they will rub on wide rims. True?
Darceking
by Darceking
What year EVO ?
My brother has a 2013 EVO Hi Mod and can't run 25mm Michelin SC Pro because of frame rub. Wheels were Mavic Kysriums SL & Fulcrum Zero Nite
superdx
by superdx
I have 202 tubulars on 25mm tires, no rub, plenty of clearance
grnrcr
by grnrcr
The 202 tubulars are narrower than the FC clinchers but it's good to know they fit for you. Frame is a 2014 non-hi mod.
RBJ2206
by RBJ2206
I have a 2013 evo non hi mod with mavic 25c tyres on roval Rapide, rims 22mm external with no issues.
wrenegade
by wrenegade
I'm running 25mm Veloflex Corsas on 303 FC clinchers with on my Evo with no problems.
0302
by 0302
Can we revisit this topic?
Can we list years?
I just got my 2014 EVOs (non hi mod) second hand and tried to fit my Fulcrum 5 LG (24mm external width) with Continental GP4000SII 25c and I have rubbing on the drive side chain stay on both frames. I'm bummed. I'm glad I still have my old racing 3s, but I've started liking the wider rims on my CAAD 10.
tinozee
by tinozee
Some people had alignment issue with EVO rear dropouts. Also make sure wheel is dished evenly. I use 2013 Zipp 404 FC tubs in 2014 Evo Himod team and have perfectly aligned wheel, few mm on either side, no rub at all ever.
Svetty
by Svetty
My EVO has always had the rear wheel ever so slightly inclined towards to NDS chainstay. It's marginal and I've never had issues with rub (25 mm tyres on SL23 rims) but it's there.....
sovereign
by sovereign
Svetty wrote:My EVO has always had the rear wheel ever so slightly inclined towards to NDS chainstay. It's marginal and I've never had issues with rub (25 mm tyres on SL23 rims) but it's there.....
What year? Which tires?
0302
by 0302
The wheel should be dished perfectly, but I'll have to have it checked. I'm really bummed that I just got my first nice carbon frame and now I won't get to have wider wheels on it. I may try to buy a Conti in a 23 to see if that works. I'd like some more aero wheels, but if I can't get wide ones also it seems like it might be a waste other than just looks and weight. I might just settle for some Reynolds Fours.
