Vuma quad chain ring bolts help/question
Hi out there, I have 2 chain ring bolts that will not come out of my Vuma quad cranks. [ I got out the big one and a normal one]
I can drill them out its not an issue.
I did fit a normal chainring bolt in to the one [ normal size] bolt I removed but they do not sit flush like the Vuma bolts.
I will need to find replacements though what do you recommend, lightest possible.
regards Ray J
regards Ray J
I use fibre lyte chainring's ...its a question more about the bolts, what bolts are WW's using on their Vuma's
Thanks Mike.
What Bolts though are quad users opting for. Because I have to replace 2 bolts I would prefer ones that sit flush.
The light alloy ones I tired don't sit as flush as the original quad bolts and have the usual 2 pieces rather than the 1 piece like the bolts that come with the crank.
Thanks Mike
tuba wrote:i have an extra set of the Zipp OEM 3+1 chain ring bolts if needed
Thanks Tuba. It seems that I have to use after market bolts with Fibre lyte chain-rings. I'm not sure your bolts would fit [3]
Does someone know for sure if that's true?
Cheers Tuba.
