Hello ,
I am based in Germany and planning a Titanium project.
Seven got a German distributor which Makes them very attractive to me.
I am planning a roadbike with pf/ di2 ready/.
Is Seven Axiom S the right Frame or should i look Closer to the other Brands above.
Cheers marco
Edit
Other frame builder means
Eriksen, Moots, no22, Alchemy which plays in the Dame Price range
Gesendet von iPhone mit Tapatalk
Seven Axiom S compared to other Titanium US frames like Erik
Hallo Marco,
No question, builders like Seven and Firefly make great bikes. Hard to go wrong here.
I'm also starting a Ti project and after a lot of investigation decided to go with Kent Eriksen. In my opinion Kent is one of the great Ti frame builders active today. His history at Moots and numerous awards speak of a lifetime of experience. The design process is very open and enjoyable. In the end you will get a frame tailored to you that is one of maybe 200 per year vs. one of a few thousand. Shipping to Germany should not be a problem. Worth checking out as a comparison in any event.
Good luck with your build!
Can't go wrong with Seven. I have an Axiom SL and a Mudhoney SL. Absolutely love them.
Current: Seven 622 SLX | Seven OVRLND XX | Fondriest Carbon Magister | Yeti SB100 |
Retired: Litespeed T5G | Seven Axiom SL| Seven Mudhoney SL|S Works Crux |Fat CAAD 1 |
