Frame size and fit
slick1
by slick1
hi all. Still on the search for the Ti bike (see other post) and have found an Argon 18 Ti which I really like. I typically ride a 56cm C -C but the Argon is a 54cm. Could I make this frame fit me comfortably (longer stem, setback on seatpost) or would it be too small.
Thoughts???
Cheers
eagle34
by eagle34
I would say so with more seat post, and a longer stem. But if possible I would give the bike a try or test another bike of similar size.
WMW
by WMW
If you can hit your contact points without it looking goofy, it will be fine.
formerly rruff...
AJS914
by AJS914
You can't tell without knowing the stack and reach. Compare those figures to a current frame that fits you well.
The reach will tell you how long of a stem you'll need and the stack will tell you many spacers you'll need to get the stem in the right position.
jekyll man
by jekyll man
Out of curiousity, how long is it since they made a ti frame?
Official cafe stop tester
