10s Sram red black chainring 11s compatibility
C50DB
by C50DB
Hi guys,
I'm planning to put a sram red black 52t 10s chainring on my cannondale hollowgram si crank.
Will this function properly with my ultegra 6870 11s drivetrain?
Thanks!
kevhogaz
by kevhogaz
I think as long as you're using an 11 speed chain, it should function just fine.
C50DB
by C50DB
I'm using 11s ultegra chain and cassette.
kevhogaz
by kevhogaz
You should be good to go, then!!
greentimgreen
by greentimgreen
Great idea! I've been thinking of ways to make my SRAM Red22 chainset more black - the silver doesn't go with my next build. Is there much of a weight penalty?
2014 Parlee Z-Zero DADi2 & ENVE (6.2kg)
2015 Colnago C60 RSWH Campag Chorus & Mavic SLR (c.7kg)
Mr.Gib
by Mr.Gib
greentimgreen wrote:Great idea! I've been thinking of ways to make my SRAM Red22 chainset more black - the silver doesn't go with my next build. Is there much of a weight penalty?
IMO this would be a mistake. Yes the aesthetic is not what you want, but the shifting performance will not be as good and you will not have proper use of the 11 and 12 tooth cogs (the chain may catch on the teeth of the big ring when in small ring x 11 or 12.
aaric
by aaric
I didn't like the shifting of the 36/52 red black rings.
If you want something darker for red 22, you can go with the Force 22 rings, or praxis if you want to save some weight. The red 22 rings are generally heavy, but stiff. You'd probably save some weight with other rings. see viewtopic.php?f=3&t=103730&start=270
kevhogaz
by kevhogaz
I put Praxis 52/36 rings on my RED crankset with the hidden bolt, and the pin that goes between the ring, and the crank arm didn't line up. Kind of a pisser.
