'Non Paired' Chainrings
Valbrona
by Valbrona
I notice that companies are these days heavily into pairing chainrings, like 36/46 or 34/50 or 36/52, which is great if you want to use those combinations.
For those that don't there are Stronglight and TA rings. But are there any other quality chainrings where the largest isn't designated for use with any particular smaller one.
I am using 34/46.
Thanks.
shimmeD
by shimmeD
CT2 46/33 along with 12-25 and 11-23, without much desire to change.
Do Praxis recommend pairing?
Less is more.
Marin
by Marin
You can use any outer/inner combination you want as long as the lateral spacing is correct.
Manufacturers just love claiming things are incompatible, I wonder why...
Delorre
by Delorre
Marin wrote:You can use any outer/inner combination you want as long as the lateral spacing is correct.
Incompatible is maybe one step to far, but I can understand that combining chainrings that are not designed as a duo, can deteriorate shifting a little bit. I've used campy for year in a 50-39 combo, and shifting was more than OK, althoug maybe not a smooth as with the intended 34 inner. I think you can go ahead without to much risk. Only exception : DA9000 + DI2, with reported big ring failure due to not authorised combo's (50-39 to name one..) I've currently 50 - 36 on my 9000 crankset. Experience will tell if everything keeps going strong.
XCProMD
by XCProMD
I've had a case, though it was MTB, in which shifting from small to big was close to impossible due to rings that were incompatible.
Ebruner
by Ebruner
I run Campagnolo Super Record 11 rings in a 36-50 combo that are not "paired". They shift fine, but there is the occasional crunch from not having perfect timed ramps as in a correct pair. EPS muscles it across with no problem though.
-Eddie
headwind816
by headwind816
I've been running 50/36t FSA super chain rings (11-speed rated, meh) for 2 years with no issues. I know FSA states the 50t should be paired with a 34t and that the 36t should go with a 52t (strangely enough, the 36t does not include a pairing for 46t), but I find the 50/36t combo to fit all my needs.
HTML
by HTML
Currently using a 33t (11spd) inner with a unramped 46t (10spd) outer ring on 11 speed Di2. Never misses a beat. Both chainrings are made by Stronglight.
hasbeen
by hasbeen
39-55 Campy 11. 10spd front der. Works fine for me.
Casati Vola SLi and Dolan Preffisio
viewtopic.php?f=10&t=108931" onclick="window.open(this.href);return false;"
btompkins0112 wrote:
It has the H2 geo......one step racier than a hybrid bike
Philbar72
by Philbar72
53/36 and 52/36 on both bikes one with DI2 and the other with normal ultegra 6800.perfect.
benzebub
by benzebub
planning to go 50/36 on ultegra 6800.. any experiences with this combo?
But I could be wrong
tabmaster
by tabmaster
Look at it this way: If you poke your nose into the back of any pro team service truck you'll find a myriad of chainring sizes, both inner & outer. It'll work just fine. That said, I've been trying to get a TA 50t chainring to work on a campag 11v setup & whilst it's fine in most sprockets it just makes a racket in the larger ones. I'd go do far as to say it'll work fine provided you stay with the same make of chainring.
Paul.
If the grand tours are like classical music, kermesse racing is punkrock, Belgian style.
Colnago C50, Campag SR11
Valbrona
by Valbrona
tabmaster wrote: If you poke your nose into the back of any pro team service truck you'll find a myriad of chainring sizes, both inner & outer.
But you don't ... you only get the set sizes that manufacturers/re-sellers choose to sell. The notable exception being the pro-teams that have run Stronglight, like Cofidis, where they have had a wide range of rings to choose from.
tabmaster
by tabmaster
I never said anything about the ready availability of non standard size chain rings, I just said that they'd almost certainly work just fine! If it's made then the profs will have access to it. I acknowledge that us mere mortals getting our mitts on it is another kettle of fish altogether, but that's not to say it can't be done!
