Hi there,
I'm new here and have a lot of questions.
I have a 7.7 TREK Madone with DA 9000 groupset.
Anyone can help me how can I drop the weight (speed stop brakes)? Original bontragers weighs 320 gr pair. Wich trend can i use front and rear brakes to fit em madone??
7.7 TREK Madone Need to drop weight
Pretty sure you can use EE brakes on that frame. That will save you a good chunk. Besides that the wheels are the obvious place as carbon tubs will save loads, and the bar, stem and saddle can all be swapped for lighter ones.
Look at the brakes and saddle. The RXL's are great (around 1400g), so unless you're moving to tubulars, you won't be dropping much weight there.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
