Stack height - Standard/integrated headset question
iamalex
by iamalex
I'm comparing stack/reach figures for two frames; one with a standard headset and the other an integrated headset.
To get the true stack height of the frame with the standard headset should I add the height of headset component itself? Top and bottom cups?
Thanks!
Grill
by Grill
Yes.
iamalex
by iamalex
Quick off the mark, thanks Grill!
GT56
by GT56
the answer is no
the question is about the stack height of the frame
than add the stack height of the different headset assemblies to get the stack height for where the bottom of stem (or the lower spacer) will sit
Grill
by Grill
GT56 wrote:the answer is no
Ergo the true stack height for comparison will include the headset... Am I missing something?
DanW
by DanW
Stack/ Reach is a measure of a frame.
Use a fantastic spreadsheet like this to work out the effect of different headset stack, stem position, etc
http://bb2stem.blogspot.co.uk/2011/10/s ... -v100.html
iamalex
by iamalex
Grill and GT56, I think you are saying the same thing!
DanW - I'll have a play with that spreadsheet, looks handy.
The bad news is that I think the alternative frame I was looking at would have a bit of a spacer tower to achieve the correct fit.
