Any light weight square [ ] shape stems ?
KarlC
by KarlC
Are there any light weight square [ ] shape stems ?
Most all light weight stems are round and the squarish ones look to be heavy from what I have seen.
C64 My Sixty 4 SR EPS 12
mike
Resident Pro
by mike
ritchey c260 carbon stem
dwaharvey
by dwaharvey
Ritchey c260 superlogic? Enve? The Easton EA90 has a somewhat squarish shape to it also.
spud
by spud
Zipp os stem, new Bontrager xxx lite carbon stem are both quite square/rectangular cross section
Rick
by Rick
Does it need to be square, or just have flattened surfaces ?
VCRC has an octagonal shaped stem with flattened surfaces.
http://www.vcrcbike.com/VCRC_Team_Stem_p/teamstem.htm
rouleur01
by rouleur01
Pro PLT is not too bad weight wise from memory (maybe 135ish in 110mm?), wouldn't call it lightweight in the weight weenie world but it definitely has a square profile. Some Ti bolts would lighten it up.
mvacolnago
by mvacolnago
The Deda El is about 140-145 for a 110, not too bad for aluminum, and it is square
