What's this DA part?
Hi, here is a less zoomed in pic, I think it maybe this part...
http://www.sjscycles.co.uk/mobile/shima ... prod34069/
Can anybody confirm? Also how easy will this be to replace,
No warranty unfortunately:(
That's it. Search rear derailleur pivot botl as well. Suspect the DA bolts are ti from factory. They are simple mechanically to replace, just a circlip but...you need to wind it against strong spring tension to replace. Its not fun.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6. ; Anvil Custom steel Etap;1996 Colnago Technos Record
http://www.torontocycles.com/Selling/Derailleur.html -aftermarket bolts
Park tool has a great page on rebuilding derailleurs with some tips on how to deal with the spring.
i feel you bro
just broke a dura ace 9000 rear derailleur on my friend's bike
broken carbon cage and bented bolt
luckily in my LBS had a stock of broken RD, it's an Ultegra 6870 Di2 Short Cage
and my other friend had a broken 9000 RD because of crash
so i rebuilt the broken DA 9000 RD with alloy cage from 6870 RD and bolt from other broken 9000 RD
Look at Park's instructions-you remove the c clip from the back of the bolt, but do it with an understanding that its all under spring tension, so things want to fly apart. The bolt isn't threaed to anything in the derailleur, just held with the c clip.
