What's missing on this C'Dale Evo BB?
Multebear wrote:I really don't know, I just thought it was BB30, because of the big BB30 sign under the down tube (see pics)...
PF30 is BB30, just a pressed in version. Sell your BB and get the correct PF30 version.
Rob English "Mudfoot" 29er | Focus Izalco Max | Firefly #194 Stainless XCR | Firefly #277 | Neilpryde Bura SL 11.9 | Crust Evasion Lite
I've got this one:
http://www.praxiscycles.com/product/shi ... ersion-bb/
It says both BB30 and PF30, I guess it's supposed to fit...
- bikerjulio
OP, on your link above is an installation video that covers a PF30 installation.
(insert snarky comment here, deleted)
https://www.youtube.com/watch?v=5eeT7c7XcqcA
Are you sure you should be doing this?
There's sometimes a buggy.
One.
One.
My hunch is you need to slip the sleeve over your existing bottom bracket. If you look at the instructions
http://www.praxiscycles.com/wp-content/ ... ctions.pdf
You will see for a press fit it requires the sleeve, but a bb30 it does not. That should make up the difference. (Never used one just read the instructions)
I own both the Shimano conversion bottom bracket and the M30 bb, and you will need to purchase the $8 dollar sleeve to make it fit a PFBB30. I used the sleeve on my old NeilPryde Alize, but I no longer use it when I switched my crank over to my CAAD10.
I hope this helps.
I hope this helps.
