Creaking cable housing
- Frankie - B
- Admin - In the industry
WD40 does nothing good for your bike/anything else other than it smells ok. Please use a silicone based lubricant.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!'Tape was made to wrap your GF's gifts, NOT hold a freakin tire on.'
I had similar issues with my Powercordz. I was running them in Aican Bungarus housing. I ended up taking everything apart and found the Powercordz cable outer lining was no longer smooth. Powercordz are not very forgiving in terms of dirt and dust build-up. I would suggest inspecting the cable if lube doesn't work.
