Hello
Anyone that as a Thm Scapula F fork as tried to fit wide rims with 27mm brake tracks... By trimming the brake pads...
Maximum brake tracks in manual is 23mm, so i need to trimm 2mm to each brake pad.
Rims would be ENVE SES 4.5
Enviado do meu C6903 através de Tapatalk
Thm Scapula F with wide rims
I had a Storck 0.6 with that fork and Enve 3.4's. Trimming was a real pain as then the pads didn't last that long.
The brakes didn't have that much power either when you effectively lost that first 2mm of stroke and leverage.
My suggestion would be that if you haven't bough the ENVE's yet - Don't with this fork. Lightweights would look fantastic on it and work a lot better, or get something else that is narrow.
Xentis would work as well - or old style Bora's if you are running Campy
