Mavic 40c Hub service
Wonderman
by Wonderman
Guys
I'm trying to get into the free hub and every video or description I read says insert a 5mm Allen key in either side and twist, now a 5mm Allen key will go in one end but the other end is too small and is too big for the next size down?!
Any ideas? ImageImage
sharkman
by sharkman
did you remove the black cap from the axle on the non drive side (the cap that is clamped against the frame)
Jepas
by Jepas
Proceed as the following picture:
From Mavic Tech Support regarding Mavic Cosmic 40C
Wonderman
by Wonderman
Ahhhh sorted!! Thanks guys I didn't find that pic when I googled mavic free hub removal
Valbrona
by Valbrona
Yes - Mavic fix their freehub bodies on their hubs in one of two ways.
Wonderman
by Wonderman
So....I did this and then when re attaching the bolt I put it on the wrong way round and it's broke :( I've spoken to Mavic and I have to buy the whole axle assembly, any ideas where I could get just the bolt?
