Trail on the Colnago C60
It's probably high and correct. I had a 53 level top tube and the trail was a lot. 43mm rake paired with a slack 71.5deg ht. I think that's a trail of about 6.8mm
I really like that about the bike. It was rock solid on fast descents. I'm not a crit racer kind or rider. I prefer fast, sweeping turns and a stable bike at high speeds.
- Contact:
My calcs attached. Red is assumed, blue is calculated.
What are you using for fork length a-c?
I had a C40 and Star fork. Not sure if it has changed much over the years.
- Contact:
Back calculating from stack the a-c is right around 370mm
